Losi XXX-S
Thanks for the tip but you're right, after figuring in shipping, it's the same as buying local.
Anyone used a spool in the front like the one IRS offers?
Hey just want to know if anyone has the dynamite belt cover? Is it different then the one that comes with ghaphite conversion?
Originally posted by James Nguyen
Your CVDs are binding from excessive cvd angles. You need to glue a washer to the spindle to limit the amount the spindles can crank. Then make some setup changes to get the car to have a little more steering.
And yea i have the CF bottom cover.. Cant tell a difference..
Originally posted by JRX-S Bill
I try to make it so I don't see the bottom of the car too often.
Originally posted by HarshGuy
Really? ...humm ....j/k
What? I ONLY suffered three traction rolls on Saturday. Unfortunately, they were all during the race. Sunday...none.
See...I try...
Harsh,
See...I try...
Harsh,
See...I try...
You should have only suffered "ZERO" traction rolls.
See...I am trying...and learning...he, he...
Can a guy buy Losi O degree rear wheel...
in non-offset hubs in the molded graphite? I can't find them anywhere. Only in the XXX-S kit. Anyone have the part #?
Re: Can a guy buy Losi O degree rear wheel...
They are Part No. LOSA9847. If you can't get them, I have a couple unopened sets. I tend to use the 1/2 degree ones.
Bill is that in the offset or...
non-offset? Thanks.
Re: Bill is that in the offset or...
non-offset? Thanks.
non-offset? Thanks.
Here is the Losi optional parts list for your info.
http://www.teamlosi.com/partlist/parts/graphite.htm
bill go to www.roadragehobbyspeedway.com i sure they have all the non offset rear hubs go to the website and get the number and if you do it now they should be there or will have to wait until tues>
ONE WAY
Ok guys, here's the challeng I'd like to find a US supplier of an aluminum or steel (preferably aluminum) one way out drive for my one way. It would seem as though no one makes this or sells this in the US and I don't know why. mine are practically ripping aprt from use in a 19t class I don't know how the pros can do it in open mod unless they're getting that one-way from Japan. any one have any suggestions?
