Like Tree2Likes
Losi XXX-S
Old 02-07-2005, 08:49 PM
  #12796
Trader Rating: 16 (100%+)
Originally posted by STLNLST
When are you going to get the car that matches your name.....LOL It's okay to change it back for a while
Hmmm...Well how about STLNFST then????
Still Bill is offline
Old 02-07-2005, 09:13 PM
  #12797
STLNLST's Avatar
Trader Rating: 32 (100%+)
I have ALL copy rights to all names starting with STL.....LOL
KSI- the XXX-S came with two different size wheels hexs' The larger one's will allow you to run the TC3 wheels. Even if you don't have any they are real cheap should you have to buy a set.
STLNLST is offline
Old 02-07-2005, 09:24 PM
  #12798
Hey! When did the Team Br00d thing happen?
Old 02-07-2005, 10:51 PM
  #12799
Matt Howard's Avatar
You have to keep an eye on him, he changes sponsors like he changes underwear, once a week!
Matt Howard is offline
Old 02-08-2005, 04:33 AM
  #12800
HarshGuy's Avatar
Yea ...I'll be picking up some br00d motors ...and posting dyno runs shortly.
HarshGuy is offline
Old 02-08-2005, 04:37 AM
  #12801
here we go again
Old 02-08-2005, 04:46 AM
  #12802
Originally posted by karter
Anyone have a good set up?
Heres our current carpet setup (its from one of the UK Losi drivers)
Front
White Springs, 50wt, hole 3 on tower, Arm forward, 4mm ride height, ackerman forward, no sway bar, 2R block with low roll centre, 4 deg caster blocks, no toe in/out, camber link new hole above 2 & 3, AE hex
Rear
White spring, 50wt oil, hole 3 on tower, outside on wishbone arm back, 4.5mm ride height, std hubs (2 degree toe in), Smiley face Rear block in low holes, Low roll centre blocks with 1mm shim underneath (to give flat arms), no sway bar, camber link 6B
1 deg camber all round, TL or PD alfa or PF mazda shell, tyres, normally Plaids n purples, cells forward
Think thats about it.... hope it helps
Oli
Bigger Brother is offline
Old 02-08-2005, 05:21 AM
  #12803
Hi,
I purchased a bunch of xxx-s parts from another racer and i am confused about the low roll center vs high roll center blocks.
Are the taller blocks the high roll center blocks or the low roll center blocks? My first instinct wants to refer to the taller blocks as high roll center, but by raising the arms, i am lowering the chassis. Does this make them the low roll center blocks?
Can someone please point out whether the taller blocks are high or low roll center.
Thanks,
Karen
KBailey is offline
Old 02-08-2005, 06:39 AM
  #12804
STLNLST's Avatar
I won't comment on the web on why I switched. Did you ever get my email as to why??
STLNLST is offline
Old 02-08-2005, 06:40 AM
  #12805
STLNLST's Avatar
Don't do your same break in proceedure that you used on the Brahma motors.....LOL
STLNLST is offline
Old 02-08-2005, 06:47 AM
  #12806
HarshGuy's Avatar
Hey I figure I gotta be fair in my comparisons and gotta treat them the same ...gotta compare apples to apples.
HarshGuy is offline
Old 02-08-2005, 07:01 AM
  #12807
Harsh,
If you are coming to Stockton on Saturday, I can show you two of Br00d's Monster-based stocker motors. Had em since December.
Old 02-08-2005, 09:16 AM
  #12808
Yeah I got it, I still gotta tease you though
Old 02-08-2005, 09:46 AM
  #12809
can u guyes put in some pictures of ur xxx-s so i cn c ur set ups, plz. thanks
jake1990 is offline
Old 02-08-2005, 05:59 PM
  #12810
karter's Avatar
Front
Rear
Oli
Thanks I might have to put that set up on here.. Were they running on Ozite carpet?
karter is offline
