Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 01-27-2008, 10:34 PM
  #24931
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Darkseid
Let me make sure before I say that...
Do I need the send the originals in?
If so, do you need the whole universal or just the dog bone?
I'm pretty sure that you can just call in and get the replacements, the old ones would probably get thrown in the trash anyways..
Going to bed, got an early flight, see you guys at the 'Birds!
Randy Caster is offline
Old 01-27-2008, 10:56 PM
  #24932
JayBee's Avatar
Trader Rating: 31 (100%+)
Good fortunes Randy!!
GO TEAM SCHUMACHER!!
JayBee is offline
Old 01-27-2008, 11:50 PM
  #24933
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Good luck at the birds guys...
rx7ttlm is offline
Old 01-28-2008, 01:02 AM
  #24934
ROBORAT's Avatar
abailey: i figured its a weekend over there so im finishing my order list while your away from the office. would you know what the part number is for the servo horn set? not the servo saver, just the straight/direct horns. thanks!
ROBORAT is offline
Old 01-28-2008, 05:40 AM
  #24935
Regional Moderator
Darkseid's Avatar
Good luck to you guys at the 'birds!
Darkseid is offline
Old 01-28-2008, 05:44 AM
  #24936
Good luck to the Schumacher guys at the Birds
SRW141 is offline
Old 01-28-2008, 05:51 AM
  #24937
MagicMarker's Avatar
Good Luck Guys!!! Have a good one and bring home some hardware for Schui!!
MagicMarker is offline
Old 01-28-2008, 09:58 AM
  #24938
squarehead's Avatar
Trader Rating: 75 (100%+)
Originally Posted by JayBee
Here's a few...... for next time I gotta have more white on the nose.
Pics no workie...
squarehead is offline
Old 01-28-2008, 10:14 AM
  #24939
squarehead's Avatar
Thumbs up
Well, it was the maiden voyage for my Mi3 yesterday, but I chose to just get a few practice sessions instead of racing with it. Out of the box, it worked REALLY well, with just a bit of hard push entering fast corners (like the end of a sweeper or carousel). I'm running a front diff until I can find a HD one-way for the front, but it worked really well as-is. Gotta say, after my train wreck in 1/12th scale yesterday, I'm looking forward to racing this car a LOT.
So far, so good, even though I was about 85g light with a LiPo in it. Needed a LOT more weight than I had space for... but tungsten pinewood derby weights work great so far.
And now, some pic whoring...
Old 01-28-2008, 10:27 AM
  #24940
TimPotter's Avatar
Trader Rating: 15 (100%+)
Doug, maybe trimming that airbrake of a wing down may help with that high speed push .
Too much T/A for you...
TimPotter is offline
Old 01-28-2008, 10:34 AM
  #24941
squarehead's Avatar
Heheh yeah, good point. Not enough testing time with the new car, and the rear spoiler IS huge.
Trans Am is just so derned fun, and I'm intellectually capable of managing 3 cars at one time, so this one sat on the bench Sunday. It won't again, though.
Old 01-28-2008, 12:03 PM
  #24942
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
very nice paint job!! how about shooting one my way
Marcos.J is offline
Old 01-28-2008, 12:15 PM
  #24943
Regional Moderator
Darkseid's Avatar
ApexSpeed: that battery strap your using...is that the standard Mi3 battery strap U2985, with the little raised middle section removed?
I wanted to use the strap for my lipo too, but didn't know if I could remove that raised section.
Oh, and can I get a look at the car without the body on. I'd like to get a better look at the strap mounted up.
Darkseid is offline
Old 01-28-2008, 12:18 PM
  #24944
Super Moderator
Marcos.J's Avatar
the MI3 strap works great its easy to take out the raised section just takes a few seconds to move it where it need to go and it just slides out , justremember to add 3mm worth of shimd on the bottom of the post for the Core Rc pack.
Marcos.J is offline
Old 01-28-2008, 12:58 PM
  #24945
squarehead's Avatar
The NiMh center was yanked out (it's easy to remove, just flex the strap a bit and twist) and the strap was put bacl on when I realized how underweight the car was with a LiPo. I actually had a 3600 in there before, but it's lighter than the 4800, so I stuffed the Platinum in.
The battery is taped in, then the strap to keep it from moving around at all. I used 1mm washers under the posts to get a snug fit, but with the tape, it's not crucial to have it fit so tight.
The weights are tungsten pinewood derby weights, taped to the side and the front of the pack. The car is still a hair under 1500g, so it needs more. I don't particularly like the taped on weights, so I'm considering designing a brass tray for LiPos to fit into the slots of the Mi3 (pops is a machinist ).
