Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 01-29-2008, 07:21 AM
  #24961
Trader Rating: 37 (100%+)
Just wanted to say good luck to all the schui guys at the birds. Wish I could be there, bad timing though. I'll be there next year. Hope everyone has a good time and that Schumacher brings home some hardware.
Bertetto is offline
Old 01-29-2008, 10:07 AM
  #24962
baf1's Avatar
Default YO WES .....
TRACTION COMES UP.. SPRING LBS GO DOWN...
baf1 is offline
Old 01-29-2008, 01:35 PM
  #24963
Skiddins's Avatar
Originally Posted by JayBee
Hey guys what do the U3221 wheel hexes look like?
From the outside, same as the usual items, they have a slot cut into the back for the pin and obviously no groove for the O-ring.
They only problem is they can sometimes get stuck in the wheels and it is easy for the pins to fall out (though not while the wheels are attached.
Skiddins
Skiddins is offline
Old 01-29-2008, 02:00 PM
  #24964
JayBee's Avatar
Trader Rating: 31 (100%+)
Skiddins
Thanks....I have those, but I don't think they pose an advantage over the stock ones.
JayBee is offline
Old 01-29-2008, 11:45 PM
  #24965
They are way better, if you run modified and spool or oneway. With the stock ones and 1mm wheel spacer the contact patch between the wheel & hex is very narrow, only the outer half of the hex makes contact (~1mm width), the inner side actually sits outside the wheel (due to the spacer) and the o-ring groove is wasted space. The result is that when you slightly brush a wall or other immovable object, the hex will cut itself through the wheel quite easily and you'll have a 3WD car. With the U3221 the contact patch is a lot wider (due to no o-ring groove) and this problem doesn't exist.
I only run those on the front axle, never had a problem with the original rears, because the diff will give up instead of the wheel.
olev is offline
Old 01-30-2008, 04:02 AM
  #24966
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
it keeps the rims from rounding off I only run them in the front
Marcos.J is offline
Old 01-30-2008, 03:09 PM
  #24967
Trader Rating: 42 (100%+)
Snowbirds Round 1.
Goetz in the game...
Position Name # Laps Time Fast Lap-Time
1 Brad Johnson 28 5:03.04 4-10.4
2 Chris Goetz 28 5:03.56 5-10.5
3 Jason Schreffler 28 5:08.30 20-10.6
4 Jeff Cuffs 28 5:10.48 3-10.7
5 Justin Lessard 27 5:00.13 8-10.6
6 TJ Bradley 27 5:01.96 17-10.8
7 Stephen Boice 27 5:03.13 4-10.9
8 Bill Sydor 27 5:03.89 8-10.9
9 Mike Haynes 27 5:05.27 2-10.9
10 Mark Strasnick 27 5:07.10 9-10.6
Nexus is offline
Old 01-30-2008, 03:13 PM
  #24968
Kevin K's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Nexus
Snowbirds Round 1.
Thats not bad for practice...keep it up Seabass
Kevin K is offline
Old 01-30-2008, 03:22 PM
  #24969
wallstreet's Avatar
Trader Rating: 24 (93%+)
your talking about the practice pimp seaball
but for real
Good Luck Seaball you put in the time, best of luck
wallstreet is offline
Old 01-30-2008, 05:13 PM
  #24970
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Kick ass sea bass...
Has anyone run both the speed passion Brushless esc and the LRP TC, Just checking the pulse on that deal..
rx7ttlm is offline
Old 01-30-2008, 05:23 PM
  #24971
R/C Tech Elite Member
abailey21's Avatar
I have run both
Beep beep beep beep <--pulse
You like that, don't you
I almost have your screw kit ready!
abailey21 is offline
Old 01-30-2008, 05:54 PM
  #24972
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've run both. They both feel very similar on the track. But the adjustability of the Speed Passion is a great thing.
Jon Kerr is offline
Old 01-30-2008, 06:15 PM
  #24973
JayBee's Avatar
Thanks guys for the wheel hex tips. I guess that's why last summer I had a few 'rounded-out' RP30-36's.
Btw...does anyone see a potential issue with running the lowered shock towers on rubber/carpet?
JayBee is offline
Old 01-30-2008, 06:59 PM
  #24974
rx7ttlm's Avatar
Originally Posted by abailey21
I have run both
Where are mah screwz!! Are ya makin them yourself? lol try not to let fabulous push you around to much..
rx7ttlm is offline
Old 01-30-2008, 07:22 PM
  #24975
abailey21's Avatar
To be honest i've been bombed lately and I keep putting it off.....on one point unacceptable, but on a different point.. well yeah I'll email you tomorrow
Or call me, but make it late afternoon
