Schumacher Corner
hey, the part number is tnm2564w, i bought 2 pairs, each pair cost 39,00 usd
ok lol found some
which of these would be the better buy:
TNM2564S Steel C.V.D. Mi2/R12 - Mi2/R12 $29.99 or
TNM2564W TiR Worlds Edition CVD - Mi2 $39.99 ??
is the worlds edition titanium aluminium or steel?? if there titanium ill spend the extra cash but otherwise just go the steel??
id prefer on my old mi2 the tnm2564w (titanium)
they are really light and dont break
Originally Posted by P-DUB
Not really...The hex pin is further out and will make the car wider
They are alloy, I don't think TiR make any driveshafts out of titanium, they use a stronger aluminium alloy though.
Skiddins
Originally Posted by Skiddins
I thought the driveshafts were the same for the EC and the Mi2, TiR do a version that has a slightly longer dogbone to go on the front of the EC, I bought a pair of these for my EC.
Skiddins
Skiddins
about how much will these driveshafts cost me??
are they more expensive than the steel drive shafts?? cheers
Just to confuse things i run the black steel Mi2 driveshafts on my EC, all you have to do is run old plastic hexs from the Mi2 ands you'll end up with the same width as the EC when using the white spacers.
Originally Posted by IslandBwoy
Brian,
Did you try the one way setup over the weekend? I'm thinking about trying it at superior next weekend. Not sure what will happen
yes he did..... FAST
Beautiful. Nice going B. Must have taken some pratice getting use to no brakes on our tight track.
w/ no sways
where can i download a blank set up sheet
Originally Posted by teammidget lilB
wasnt to bad but i added a couple of things i put 6 degree c-hubs w/ adjustable toe in blocks i ran 3 degree toe in
Originally Posted by Jon Kerr
Adjustable toe blocks? As in the plastic pivot blocks from the Mi2?
