Schumacher Corner
So with the mods that we are seeing so far (slotting the camber holes on the shock tower to adjust for lowered diffs; running carpet top decks for outdoors etc..) is it possible that we will see some of these part being offered from BMI? I wouldn’t mind seeing a package of varying top decks for different setups or a pair of shock towers if not a entire chassis to give us more options.
Originally Posted by 20 SMOKE
Tweak ?
if you set the car up shock are the same ride every thing dead nut put on the tweak station adjusted the car for tweak and then re check to see what it did to the ride hight and it's of by almost 1mm off from left to right is the chassis tweaked
Loosen the top deck screws at the end which has the problem, twist the chassis in the desired direction (which ever way will get rid of the tweak), while holding it twisted tighten up the allen screws.
This seems to get rid of any tweak.
HTH
Skiddins
thanks I found the problem the station is off from left to right so its going back
Iv got a couple of ? one on the bulk head where the motor screws go for the gear mesh has anyone had the problem where the holes arnt the slitist bit big enough because depending on the gear but i run a 112 spur and when i gear between 7.00 and higher when i tighen the screws they grip the bulk head and move the motor/gear mesh. two I know the mi2ec generally has alot of slop but im getting castor slop and it seems that when I get in a sweeper i will find the lane i want early on but as the car progresses through it will change lanes and im pretty sure its because of the castor slop. what im working on right now to get rid of castor slop is im sanding down the c-hub where the hindge pin goes and im going to put a aluminum spacer inbetween the arm and the c-hub will this help prefent castor slop.
mi2 shocks
Hi.
Can anyone tell me how to build mi2 shocks. the book is really not that clear. Is the shock suppose to have full travel after it has been re-filled. I think mine's too hard cause I cannot compress them completely. If I drain a littlebit oil, I can compress them but they dont return completely.
Please help...
Please help...
Originally Posted by brakkie
Hi.
Please help...
Please help...
get the trf shocks easy to use alot of people have done his or get the ec shocks that some one posted on your post the older shock you have to play with it to get it rite
Hi.
Please help...
Please help...
As for building them....try filling the shock body with oil then placing the bladder over the filled shock. Some oil will drip out. Tap the bladder so it sits flat on the shock top. Now screw everything together. That should give you just about the right rebound.
I'm sure some of the other guys on this thread have other methods to try as well.
Nexus - I think you misunderstood the question, the shocks in question are the original MI2 shocks which are indeed a pain to build. I havnt built any in a while but there will be instructions somewhere within these 500+ pages I never got them perfect with no air at all, i too recomend the TRF or EC shocks if you have the cash. They will be easier to build along with being able to get more droop when using the outer shock position holes on the lower wishbone.
I need your help. I need contact with IslandBwoy. Please give him my email [email protected]
Victor
Victor
hey guys,
i stood my rear shocks last weekend and it settled the rear end down in the switch back but i noticed on out sweeping high speed corners i have to lift where other drivers can just steer thru can u guys give me and set up tips or driving tips for high speed sweeping bends?? btw im only .5 a lap of the fastest so i dont think im loosing that much but just wanna try and perfect my set up,
cheers, Josh
cheers, Josh
Originally Posted by aus jd 2703
hey guys,
cheers, Josh
cheers, Josh
Victor
Victor
You rang? pm sent.
you
hey guys,
cheers, Josh
cheers, Josh
It's that time again
Roll call for the IIC Vegas race Anyone running Schumacher cars attending please let me know.
