Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 08-23-2006, 02:32 PM
  #15811
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by teammidget lilB
yep
OK. First thing I thought of when I read "adjustable Toe blocks" was the way the rear was setup on the original Mission and thought you'd done that somehow.
Jon Kerr is offline
Old 08-23-2006, 02:33 PM
  #15812
Trader Rating: 42 (100%+)
where can i download a blank set up sheet
You can find a blank and drivers setups on Schumacher Pitspace
http://schumacherpitspace.com/setups.htm
Nexus is offline
Old 08-23-2006, 02:50 PM
  #15813
PW
PW's Avatar
AWESOME! Thanks Nexus
PW is offline
Old 08-23-2006, 03:00 PM
  #15814
STLNLST's Avatar
Trader Rating: 32 (100%+)
PW- What color dress should I pick out for Weylin???? Maybe something that matches his paint scheme....LOL
STLNLST is offline
Old 08-23-2006, 04:43 PM
  #15815
wallstreet's Avatar
Trader Rating: 24 (93%+)
Paul could you explain the differences between the cs-27 and the rp-30 tires. I read it somewhere but i cant find it now.
thanks
wallstreet is offline
Old 08-23-2006, 05:13 PM
  #15816
hey nexus when u going to put that steering mod up on pitspace been looking for it?
aus jd 2703 is offline
Old 08-23-2006, 06:51 PM
  #15817
P-DUB's Avatar
thanks
The CS27 was originally developed for durability with minimum loss of performance (CS = Control Spec), but they did such a great job in developing the tire it became a great race tire.
The RP series has a much thinner carcus to dramically increase intial traction for greater performance, at the cost of durability. Once again they did such a great job in delvelopment we ended up with high performance and durability.
The RP seems to have slightly more steering producing faster laptimes
P-DUB is offline
Old 08-23-2006, 06:54 PM
  #15818
wallstreet's Avatar
which of the 2 has a bigger drop off in performance
Old 08-23-2006, 06:57 PM
  #15819
P-DUB's Avatar
Really depends on the surface. I think on highbite smooth surfaces the RP actually falls off less than the CS series
Most people don't realize that less traction normally causes higher tire wear because of sliding and spinning
P-DUB is offline
Old 08-23-2006, 07:01 PM
  #15820
wallstreet's Avatar
it would be high bite carpet. very intresting
thanks for the info
Old 08-23-2006, 07:03 PM
  #15821
Trader Rating: 19 (100%+)
semes like when the cs has a gruve its not a race tire but the rps have lots of traction w/ the grove i like rps also the cord shows on the outside of the rp before the inside RP
teammidget lilB is offline
Old 08-23-2006, 09:26 PM
  #15822
Sorry...I've been on vacay from my real job and slacking on some updates :P
I will try and work with Kevin Kane on the details and get it done soon.
Nexus is offline
Old 08-24-2006, 08:58 AM
  #15823
mini-dub's Avatar
Trader Rating: 16 (100%+)
Didn't you have a pink body at one of the races? I think pink would go nicely with your curly blonde hair you have.
mini-dub is offline
Old 08-24-2006, 09:10 AM
  #15824
Jon Kerr's Avatar
Watch the PINK comments!
Jon Kerr is offline
Old 08-24-2006, 11:35 AM
  #15825
STLNLST's Avatar
tHANKS for defending the pink
Weylin- what have you been up to man? we are gonna have a blast in Vegas and with you being a minor....I will need your mom's permission to put a dress on you
STLNLST is offline
