Xray T1
#8596
Originally posted by kerry
i would appreciate some feedback on the following question.
when assembling the rear arms, they do not move up and down freely with the 2mm toe in clip, what can i do to resolve this issue? with the clip in it pushes the back out and thats when it binds, with the clip out it moves up and down freely. has anyone else had these problems if so what was the answer.
thanx in advance
thanx in advance
#8597
Originally posted by theisgroup
light weight diffes
light weight drive shafts
new bulkhead
low ratio pulleys
light weight out drive for one way
new shock towers rear
carpet shock towers front
light weight axles
short arms
solid top deck
lower suspension holder with aluminum nut
lightened solid aluminum layshaft
shorter pivot pin holders
shorter turn buckles
all captured ball ends
composit bumper.
these are the obvoius changes. I know there are more
light weight diffes
new bulkhead
low ratio pulleys
light weight axles
short arms
solid top deck
composit bumper.
#8598
Originally posted by Besercoe
The instructions advise that you may have to sand down the clip a little to maintain free operation of the arm, this ensures that the arm has zero slop but also allows free movement.
#8599
#8600
thanx in advance
thanx in advance
#8601
Originally posted by glide 1
just run the car a few times and the binding should go away, at least this is what happened with mine and it is perfect now with little or no play at all. If there is really bad binding (which i doubt) then you may consider sanding the spacers a little.
But as Glide says - try running your car a little first as everything needs to bed-in. Then and only then, sand the spacers a little until everything works smoothly.
Cheers, Mark.
#8602
Sanding does help, a dremel will get faster results if you have a steady hand. A disaster if you have a heavy hand.
#8603
Anyone know a good place I can order Xray parts on-line that is in Europe or Asia where they didn't have distributor problems?
#8604
Good service, good prices!
#8605
#8606
That looks like a pretty good site except they dont tell you if they have it in stock or not.
I've placed orders a few times on a Sunday and had the parts delivered on the Thursday!!! Thats from Holland to Germany which is pretty good going
I don't order from virtually anyone else these days.
#8607
For example last week I wanted to order the Xray anti-roll bar kits - I couldn't find them on the site I emailed [email protected] and within a couple of minutes it was on the site, so I could place my order. A few days later my order came! You can't ask for better service than that.
#8608
Let me know [actual $$, tax,paypal & s/h; I'm not looking to make a dime] and I'll call them and let you know if they are in stock and when I could get them & sent.
BTW, they usually beat Stormer's hobbies prices by about 10%, which would make up the difference in the tax and help cover some of the other charges. Xray is a prdominant ran kit at the track, so he does pretty well by the racers and their commonly needed kits/parts.
^5
Tom G
#8609
also ralph b. frequents the track. actually I heard that Ralph use to work there when he was a youngster
#8610
^5
