Novak Kinetic
#676
Hey Guys,
First and foremorst, thanks for all the efforts in getting things sorted out. it's a bit confusing and while I can explain how to setup an ESC, walking throught the PC Mumbo Jumbo is not my strong point.
Oh, as far as I know, Novak is the only motor with a Temp Sensor inside.
Charlie
Charlie
#677
The gm motors have temp sensors inside but it's unlikely that the readings will correllate with the Ballistic range ( if the kinetic does read from them )and be directly comparable, as the placement and type of sensor will make a difference to the reading, I know that the gm esc will take readings from the ballistic motors but not sure about the other way around yet.
Steve
Novak UK Team
Steve
Novak UK Team
#678
Hey Guys,
Well Done Sirs! Shoot me an email with the walk through if you can SkyPilot (richie right?)
Charlie
Charlie
#679
I agree. This thread has been a lifesaver.
Can you imagine the hassle involved in something like this without the internet?
I had to laugh at myself through all of this. When my first went bad, the thought was, "I cannot spend 200.00 to replace it." I'll use my gtb until my repaired/replacement arrives. So I hook up the gtb using the same gearing.
The truck goes otu and runs at about 1/2 the Kinetic speed.
Then my brain remembered it was labor day, that means an extra day delayed for repair. Then the lightbulb went off. I decided to sell the extra after it was repaired, and tying up 200.00 for a short time felt reasonable.
I knwo there have been some small issues, but this is an amazing controller worth every bit of what I had to pay for it.
#680
I Love The Internet.
#681
It is good when like minded people can share their experiences and problems and resolve them with the help of such a responsive company as Novak.
Bring on the time sheets on Sunday.
#682
Okay, so I've gotten a little better handle on the whole updating situation.
If you have problems with the update, its related to a connection issue. How the plug goes into the NovaLink. So to resolve this, you can simply leave the NovaLink coonnected the ESC, and plug the USB cable into the NovaLink when the updator asks you to "plug in your ESC".
So far not everyone has had problems, but some have, inconsistent USB stuff from what my None Computer Speaking Self understands.....
#683
Hi
Hi Charlie, Heard you made a move back! Maybe i will be able to get hold of you again. Ummmmmm seems to me you owe me dinner whenever you get back to Chicago or do i owe you dinner oh hell either way. Talk to you soon e-mail me a phone #[email protected] Mark Kaye
#684
Guys, I know you are not the offroad forum, so forgive me for asking this.
Is there a need for different settings for onroad use vs offroad? It sounds like a lot of the issues both face are similar.
If they need to be different, what are some specific things I could try for offroad needs?
#685
from my past off road experience I would say the only issue would be the proper gear ratio do to the balloning tires of a buggy or truck, using the previous setting posted by ed I would think you would be good to go in buggy or truck, 17.5 or 13.5
#687
after reading 46 pages of posts, i still cant find an answer. last night we programed the esc with windows 7 and it worked 2 of 3 times, on the third update, the esc powered off and now it will not come back on. i plug into th e 3 prong plug, all 5 lights come on for one second, then go off. the esc wont power up, will not connect
, nothin. what now?
, nothin. what now?
#688
same thing happened to me. cant reset or use the onetouch. has steering but no power to motor.
#689
, nothin. what now?
, nothin. what now?
WOW, that happened to me last week! John at Novak sent me a replacement brain which I installed. So my guess is the brain unit went bad on yours as well.
Since then, I have had zero luck connecting to Novalink on XP 32 bit laptop.
#690
Do you guys think this cable will work on our Kinetics? It might be nice to not have to disconnect the receiver every time a change is needed.
http://www.rcplanet.com/Castle_Creat...secclinkqc.htm
