The Speed Passion Thread
#9152
ok so i got the programming box today. downloaded the 508 version and still cant get the esc to blink. any help would be greatly appreciated. thanks in advance
sorry its a gt2.o pro
#9153
Make sure your throttle position on your controller is set at zero. Meaning no brake and no forward creep when car is sitting still and throttle in neutral position. My son had this issue going through tech at the carpet nationals. They found he had brakes set into the car at neutral position and when they zeroed it out the Speedo started blinking.
#9154
already had all trim, subtrim everything set at 0, even tried narrow to wide neutral ranges still no luck
#9157
21.5 V3
What is the recommended FDR for the 21.5 V3 on a TC?
No ESC boost or timing
#9159
Hi there, need so help with the new MMM 4.5 i run firmwear 205 with 8.1 ratio on a tamiya trf416x. default esc setup and the engine got 105ºC with a outside temp 32ºC. The engine doesnt run and get hot, wanna try the mod 119 or something that the engine will run and dont get hot, i have a 3.5 v3.0, want to try it to but need some lights on esc setup, firmwear, timing on the motor, and final gear please, i dont understand i tryied an 5.5 v3.0, whith timing on motor on max, esc setup almost everything on max whith 119 mod, and on final 5minutes the engine was on 75ºC. But the engine dont have power on exit courner. Need to do the same on temp whith a powerfull engine. Thanks in advance.
#9162
Thanks for the quick response SRW141
I am trying to get a 21.5 motor and I am trying to figure out the differences between the 21.5 MMM/ 1CELL and 2CELL motor. I don't know which one to go with. Only difference I see right now is the MMM motor cost more than the other two.
#9163
