The Speed Passion Thread
#1651
Hi Tim, I run indoor low to really good traction carpet. For 1s 17.5 I run 312 at 89-92mm have had it as high as 98, all it did was slow down a little and got up to 130-140f temps.
programmer set-up: 2.0 (LCD)
1 RM forward only
2 DBF 3-4 (10-20%)or to your liking if you use some
3 LV 1 none
4 DRRS 9 (IX)
5 BF 4 (100%)
6 RF 4 (100%) Adam mentioned max on these many pages back in the thread
7 IBF 1 (drag brake force)
8 NR 2 (9%)
9 "ATMS" timing 8 (26.25*)
10 O-Heat Protection 1 (enable)
car set-up = can-O-worms? 12th Scale thread and your chassis threads ASC, CRC, Speed Merchant etc.
Tires- what are the locals using?
chassis? you know the old t-bar vs. link routine.
pics of my 12L4 are in the 12th 1s wiring thread, it's a little different
Good Luck laying down the foam
Mark
1 RM forward only
3 LV 1 none
4 DRRS 9 (IX)
5 BF 4 (100%)
8 NR 2 (9%)
Mark
Tim
#1652
Dan
#1654
Tech Legend
Ok, I am having a problem understanding how profiles work on the LCD Programmer.
When I go to setup a seperate profile for software 1107 and software 1110:
- How do I know on the programmer what version of the software is on the ESC?
- How do I know in the USB interface which software the Mode will use?
I guess I am not understanding how to have my "choice" version stay set for the profile versus the "software" version, as stated on the usb interface? So in short, how do I have different software versions like 1107 and 1110 for different profiles on the programmer?
#1655
#1656
So who is running the 2.0 with the new software at the Novak race and how is it standing up? I know today was just practice but.........
#1658
The esc software should actually be called firmware to less confuse the guys.
In the pic below the profile/mode tab is where you select between 1 - 3
below that is a name tab that you can change to suit ie track name or label as punch/speed etc in pic below mine is 17.5 class - track is DMCC - Speed is max rpm.
Make setting changes and give profile 1 a name and then save/apply it and repeat for profile 2 and 3. Once done if you use just the lcd, when you switch it on, press the r/p button (2nd one on the right), one of the 3 profiles will come up. press value to toggle between profiles.
If you want to change settings press item ( botton on the left) which takes you into the settings screen.
Hope that helps
#1659
In the software you can store 3 different modes/profiles but only for one particular software/firmware used ie: 110 or 107.
Hope that helps
Hope that helps
In mode1: 107 profile
In mode2: 110 profile
In mode3: 323 profile
Only reason i would like to have those three profiles stored in the LCD is that i run both mod and 13.5 with the same esc. If i can't store those different profiles in the LCD, i have to carry my lap top and change the profile every time i switch to mod or 13.5?
#1660
Ok, so it is not possible to store like this below?
#1661
I have been struggling to get brakes with my SP GT 2.0 since I bought it, several software updates did not work.
However, with the new stock 1110 software I finally have brakes! Couldn't be happier, and proof somewhat that this software should give better brakes.
Also, it's quick down the straight.
Regards
Neal
Regards
Neal
#1662
#1663
It doesn't work like this.You can change the speed control's software (or firmware whatever you call it) through the program box but only if both are connected with a pc or laptop the same time.You can't change the speed control's software only with a program box loaded with a different software.With the LCD program box you can change only the speed control setting.
#1664
Tech Legend
darn. Oh well I guess then. I was hoping that the programming box would store the different firmware for the ESCs so I could test out 1110 and 1107 at the track as I am on the only one running speed passion.
A question on profiles, are profiles specific to an ESC? so lets say I use 1 LCD Programmer, I can't use the same profile on two different ESCs?
So what is different between 1107 and 1110 from those who have used them?
Also, anyone have stuck pixels on there LCD Programmer? Mine has some that came that way, its a minor annoyance, but curious if this is common.
#1665
