"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors
#841
Yokomo ant the new muchmore compound has not been
around that long
And to my knowledge have only been reliased of late
And as late as summer nats
Yes the older compound did wear a little quicker than the sorex
around that long
#842
The MM V2's (mm rim) are very similar to the sorex 36s, both in terms of outright pace and feel. The absolutes (sweep rim) give a bit more steering and are faster on most tracks by a couple tenths. I never had any problem with them overheating though, in fact you could normally go one compound softer compared with sorex and experience similar wear
It's my understanding that the v2s are the next generation of tire produced without the chemical which makes tires grippy - it's apparently rare and super expensive. If you ever used mm sweeps which were the 1st gen then you'll see how far the tires have come with the v2's! It is funny how they are faster 2nd and 3rd run compared to 1st - so backwards
#844
Ex
I was talking about 32mm which is what is ment to be run
for mod in titc10
for mod in titc10
#845
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXUDL3
From my understanding, there are two types of MM tires? One of them called the V2 used for control tire racing which have just as good grip as the sorex but longer lasting. The other called the Absolute which has better grip and last about as long as the sorex, available in only 24 and 32 deg?
update: found that the absolutes also have a 36. Should I still try the 32 to replace the sorex 36?
No one seem to sell the absolute with just the tires alone. Was thinking of mounting them myself because I read reports where the rims that come with it cracks easily. Did they improve on this?
Sorry for the many questions, but just wanted to get the right stuff the first time.
#846
Thanks guys. Are these the tires that you are referring to?
#847
Whoa, better use them only for the main. The glue part is not that bad, but are they just as brittle as the sorex rims? Love those speedmind rims that never cracked on me yet.
#848
hello Jilles, have you tested the speed passion V3 10.5? if you have tested it what's the best ratio for a largest raceway?
#849
Hey Jilles!
I was looking to get some titanium turnbuckles for my 416 the kit comes with 42mm but I saw some 45 mm. Which ones should i buy?
#850
Hi Jilles
Sometime ago u uploaded the basic outdoor rubber setup. How would carpet rubber setup differ from the outdoor? Do you have a sample that can be uploaded?
#852
Yes, great run Jilles. I would really like to see your snowbirds setup as all we run are the jaco blues as a spec tire on carpet.
Thanks.......Dwayne Flodell
#853
Congrats on the win again. I just wanted to thank you for the set up help this weekend. Just to let everyone know he told me he was going to post the set up when he got back home.
#854
Congrats Jilles on the win in states.
As we are preparing for TITC soon, any suggestions? Btw, would you be attending TITC or the EURO TC Championship, as both races has your name on it? It would be great to see you in action in Thai. Still owe you some beer man.
Cya then.
Cya then.
#855
Hello all,
Attached you will find my set-up of the Snowbirds Mod TC last sunday.
I used a box stock 416X chassis. Only "option" parts where titanium turnbuckles!
I will try to keep up with the thread again.
Best regards,
Jilles
Best regards,
Jilles
