HPI Cup Racer 1M
#1293
they fit pretty well - a little snug on the bearings, but nothing too serious
the best part is the get rid of those damn little lock nuts in the plastic HPI stock parts
I also ordered the 'short' aluminum wheel hexes as well - eye candy, but wanted something more then plastic
#1295
My green mean sliding machine!
#1296
I am planning to get this car soon and I wanted to know if a Mamba Max 7700kv system will work in this car. I will dial the system down all the way so it dosen't get too out of control. I also wanted to know if a 2s hard case battery will fit. I am going to be using this one:
http://67.199.85.166/main/productdet...ory=5101.xxxxx
I also wanted to know the total lenght of the car with the stock body.
Thanks!
Thanks!
#1297
Thanks!
Thanks!
any motor system WILL fit the car...the problem with a 7700k system will be finding the proper gearing that will not overheat the motor, regardless of you can 'dial' down the system...I don't know what the 7700kv is related to in terms of 'turns', (but i DO know its an awful lot of power) but the chassis is really made for either a 30t brushed motor, or AT MOST a 21.5 brushless motor - yes, everyone runs more power then both of them, but you run into drivetrain breakage (because its not designed for that much power for extended periods of time) since you sound like you wanna just zip this thing around your driveway or local parking lot
the length of the car with body will actually depend on WHICH body you are putting on it - you have the datsun 510, datsun 240z, toyota trueno, and the porshce 911 - all different total lengths...
#1298
Thanks for the info. I can get a brushed motor with the car so what turn should I get? I was thinking about a 15t-17t or should I get a 19?
#1299
if you plan on racing it - check with your local track to see what they are running in it...if you plan on basing with it - then put whatever you want in to...just be prepared to have parts fail or have a car that doesn't handle well because of the extra power
#1300
Fishymamba.
That battery your looking at the Reedy one.It will work but you will need to go with the oversized battery config.You'll find out about in the assembly.You will need some zip ties,or strapping tape/velcro. Read the instructions though and look at everything closely.
I went with a cheapo route. I got the 5400 lipo series venom racing lipo. That fits with the standard battery set-up but you need to trim a few things because that certain battery does not have rounded edges.It hard to find a lipo with rounded edges or so it seems for me. You would need to to trim out the battery holder a little more then what it says, and also some more on the additional pieces and it will work and it will still be a tight fit.
If you ever find something that will work with no moding. Fits and is the normal size of a 7.2 or 7.4 nimh battery please share it with everyone.
Last edited by Zach_RS; 12-20-2009 at 03:49 PM. Reason: dont want him messing his mini up
#1301
Fishymamba.
As for a motor. Dont go with anything lower then 19t, I had a 13t and the sheer torque of a motor like that WILL damage drivetrain parts.
#1302
Mods. Please delete my first reply
#1303
here are a few rounded lipo packs...didn't take much of an effort to find
http://www3.towerhobbies.com/cgi-bin...&I=LXVHA4&P=ML
http://www3.towerhobbies.com/cgi-bin...?&I=LXYCB6&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXYCB0&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXYCB1&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXYCB2&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXXCJ9&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXXCK0&P=7
that's orion's and reedy's choices at tower...I know hks hobbies have some imported ones as do rcmart....don't let the mah fool you, a good 3800 pack can and will run as good as a 'cut-rate' 5000mah pack...
#1304
I also wanted to ask what pinion gears come with the car? What tooth gear should I get for a 17t motor?
#1305
you get 1 pinion gears with the car...off the top of my head, its a 30 tooth pinion that comes with the kit...what are you planning on doing with the car? race it? bash it? if race it - what size track/what's everyone else running gear-wise?? (yes, it does sound like a lot of questions - but there isn't 1 'proper' gearings that will work everywhere for every type/size of track)
