Tamiya TRF415
Originally Posted by bender
The reason why the Cyclone has the front belt off set is so that the centre-point steering bellcrank can be placed in the correct location.
If you have a close look at the Cyclone, the cells aren't really any closer to the centre because even with the belt to one side - the spur gear is now in the way of getting the cells closer. Either the cells would have to come forward to clear the spur, or the layshaft moved back.
I think your first point is right - the MSX is well balanced the way it is.
BTW it is possible to move the motor to the middle AND get the cells closer to the centre-line - it requires the support bulkhead closest to the cells to be moved in at the lower part so the cells can squeeze in there - the Top Racing Scythe has used that idea.
Greetings Ollie
Also note that the Cyclone battery is just a tad more in towards the center, and alittle more forward in placement. I checked this holding both of my chassis together seeing the difference in layout, etc.
Anyone know the part number for the cups only for the TA05 spool ???
i dont think they actually sell those spool cups separately
I know they release the derlin ones for the 415 seperate in Japan so maybe you can but we need a part number
Greetings Ollie
Originally Posted by Ollie RDX
I think that the TRF and TA-05 Spool delrin Cups are the same!
Greetings Ollie
Greetings Ollie
e-mail rc-champ they got the delrin for me maybe they have the steel, I just bought the whole spool assembly
Originally Posted by JayL
actually the TA-05 cups are steel the trf ones are delrin......guess I should be giving wrong advice over in the RDX area....
Greetings Ollie
I can tell you now, the ta05 spool comes with steel outdrives, I have one in my box, so i do know. However the delrin cups are a direct fit onto the TA05 spool (as are the steel onto the 415)... which is what probably happened with your friend in the belgium eurocup, he had just swapped the cups over.
Ed
Ed
Ed
Ed
Greetings ollie
Does anyone know the number??
Originally Posted by JoeGlover
Hey guys I'm looking for the part number for 4 degree c-hubs for the original front suspension on the 415.
Thanks,
Thanks,
Originally Posted by Mason
50985. all the parts can be deduced here.. http://www.tamiyausa.com/product/ite...oduct-id=58320
Can someone please give me the part numbers for the battery posts and the strap? Thanks in advance!
