Tamiya TRF415
anyways thanx.. but for the mean time... i wanna hear oppinions about gearing my superstock TZ???
the racetrack is large... a nice wide stretch and technical inside.. and what do you think should be my gearing???
Originally Posted by edracer1
HELP
What type of drives do most of you guys run?
Front one-way?
Front diff?
Front spool?
The direct center drive or the one-way center drive?
If I run a Spool or Front Diff should I run the direct center drive?
Can I make a Front Diff out of the rear diff parts or only the Yokomo parts as listed in the Tamiya site?
Thank you, Thank you.
Front one-way?
Front diff?
Front spool?
Indoors - Dual one-ways (rubber tyres/carpet)
Outdoors - Spool and locked centre.
I know a lot of people like to run a diff indoors with foams, and I have found that on very low grip and tight tracks a diff works well too (with a locked centre pulley)
HiH
Ed
Thanks Tryhard ,
I was going over the close-up pics of some the cars at the Reedy Race and noticed that seems to be the usual setup for them too. But I can't tell in some of the cars. Anyway, I just ordered a spool and direct center drive. You know I haven't even gotten my car yet and I've spent over $300 on spare parts and hopups. Hopefully it will be shipped soon.
One more question, is the TAO5 center drive conversion one-way or direct drive? I admit I already ordered it with the assumption it's direct drv but now I'm not sure.
Thanks Tryhard ,
HiH
Ed
HELP
Front one-way?
Front diff?
Front spool?
Front one-way?
Front diff?
Front spool?
Well i tested the TiR spool at stafford today and it works a treat , the fact it is so much lighter than the one-way seems to aid the top speed and punch coming out of the corners. Just need some tips on how to get more mid corner grip on such a dusty low grip track.
can anyone tell me on mark rheinards rubber tire setup on tamiyas website it mentions 1 transparent o-ring for each of the shocks. does that go inside to limit the travel or on the outside of the shaft. i would think its on the outside since travel is adjusted by the droop screws. just want to be sure and learn some stuff. thanx. much appreciated!!
A common trick indoors on carpet is to use a heavier oil, but with no foam spacer, as this effectively reduces the pack (i think) of the shock, making it smoother.
Outdoors, increasing the pack (ie making the shock more responsive) could be desired. Also the O-rings are probably more consistent than the foam.
HiH
Ed
thanx tryhard. this car is alot more tuneable than my tc3. im still learning it. by the way thanx for your website. its been xtremely helpful. especially figuring out all the toe blocks!!!
Trader Rating: 31 (100%+)
glad i had my TLT-1 at the track today, needed a knuckle, lol.
Hi guys...I avoided posting this until I gave it a try and for Tamiya USA to post it but here's a sneak peak of Marc's Reedy Race setup that Kiyo kindly wrote down. We sweated it out at the track today (freaking hot) trying it out and it is money Wished I went towards this setup direction last week...doh!
Note: The foam and o-ring part on the setup sheet is blank. There was nothing in the shock except the seal. Also, I believe that the front toe is 1.5 total.
how the heck did he get the car to turn with a spool & 3deg rear toe-in ?? i tried that at the Tamiya track but my car just keep pushing. i know he's the world champ and i'm not... but stilll... what an amazing guy...
Ok wait,
The "kit" say the rear suspension blocks are 1XD ft and 1B rear (for 3-deg toe-in) but "Marc's setup" says 1XB ft and 1D. Is this still a 3-deg toe-in?
Can SOMEONE list the difference in all the blocks and explain?
If you go to Tryhard's website there is information on all the suspension block angles
Charles
Charles
Charles
Charles
Another question, are the different degree rear hubs a change in caster? For example does the 0-deg hub vs 1-deg hub vs 2-deg hub mean each tilts back one more degree than the next?
And thanks Charles for directing me to his site.
