Tamiya TRF415
Rod was the track still good on sat?
Originally Posted by edracer1
It appears that both have a 3-deg toe-in..so what has changed? I mean if both have a 3-deg toe-in, what setting is now differrent between the block sets and what is the expected effect.
Another question, are the different degree rear hubs a change in caster? For example does the 0-deg hub vs 1-deg hub vs 2-deg hub mean each tilts back one more degree than the next?
And thanks Charles for directing me to his site.
1 degree rear hub DO NOT give you caster, the change the rear toe at the hub instead of at the block..so if you had 3 degrees with the blocks and added one degree rear hubs you would have 4 degrees or rear tow per side.
Rod,
How about Corey Lewis setup or an a-main 19 turn setup for Tamiya ?
Thanks,
Kevin
Thanks,
Kevin
Hi Kev...oh man. I should have written Corey's setup down before I took it off. I'll try to post it later. Right now, it's too freaking hot and I gotta go run some errands.
Sorry there was a lil delay with posting my set up on the Tamiya site. It should be on within the next day.
hey are the springs on that Marc setup silver HPI or yellow tamiya because those are a big difference arent they?? and what is tamiya 400wt oil close to in associated or losi oil, thanks
and does anybody have a dialed mod setup for speedworld for the nats, it is very high traction last time I raced there
Thanks JayL
Can someone post a link for Josh and Marc's setup to the Tamiya site. I can't seem to find it.
Thanks JayL
LOL, sry I didn't realize that was Numan posting. I'll check back later.
Originally Posted by lbckevin
Rod,
Thanks,
Kevin
Thanks,
Kevin
Corey's setup attached:
Thanks Rod.....
Much appreaciated.....
Kevin
Kevin
any one here Know where i can pick up a complete set of the white tamiya spring set
eveywhere i look they are out of stock
JASON,
do you have a part number on the spring set ?
