Old 02-04-2010, 01:07 PM   #8416
Yeah they are for the CRC front end as well unless you cut the bottom lip off of the arm. Then they work like a charm. Too bad you can't do something like that with the R5 adapters as well.
Old 02-04-2010, 01:39 PM   #8417
2wdrive's Avatar
i use 1mm carbon spacers to set my ride height at the front. i only have to unscrew the front end just a little and then i can put the shims underneath. something like the shims in the link underneath but the holes are open on one side so i can just shove it under the suspension block without unscrewing the whole front end. Works like a charm and is very easy and fast.
http://www.amainhobbies.com/product_...eight-Shim-Kit
2wdrive is offline   Reply With Quote
Old 02-04-2010, 01:47 PM   #8418
Hi all.... Major help needed... I have been running the DB12RR with 1C Lipo and cant make runtime??? I have geared up and down and still nothing. Does anyone know the right gearing for Mod?
My set-up is as follows:
4T Motor 0 timing , LRP SXX ESC on throttle profile 4, geared from 38.5 mm to 49 mm.
At high roll out I made about 4 minutes, and at the lower I ran about 6 minutes. Keeping in mind with the lower roll out the speed was slower. It seems as if it runs as fast as 4 cell for 1 or 2 minutes and then slows down until it is very slow???
Big National event this weekend, so any help would be great. Most people still running 4 cell here and I need to stay on par.
Corally PHI/PHI 09 TEAM DRIVER
BMI DB12RR TEAM DRIVER
TOP
LRP TC SXX, LRP SXX Ver. 2, LRP X12 Octa, Futaba 3PKS Spektrum Module, Protform.
SOUTH AFRICA :)
PHI/BMI racer is offline   Reply With Quote
Old 02-04-2010, 01:51 PM   #8419
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Run a higher turn motor, unelss your really smooth with a 4t you will dump. Or get the new SMC 5600mah pack and run an RX pack also, that would help.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 02-04-2010, 01:56 PM   #8420
With mod you can not run all out all the time. You'll need to practice more throttle control then you are used to. Back when run time was an issue for stock even I used to drive only half to 3/4ths throttle even on the straights, holding back the rest for passing or maintaining my position. Also going to the least aggressive throttle profile should help some as well.
Old 02-04-2010, 04:45 PM   #8421
chris moore's Avatar
Trader Rating: 87 (99%+)
Originally Posted by EricF View Post
When you next trip to Tucson?
E
Jason and I are talking about heading down next Fri but thats not in stone just yet.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 02-04-2010, 04:59 PM   #8422
Trader Rating: 23 (100%+)
Originally Posted by InspGadgt View Post
I used to have a spreadsheet with 2 simple equations in it, one for the front and one for the rear. All I had to do was input the current tire diameter and it would output the sized ride height adapter I needed. It worked pretty good and would usually get me to with in .5mm of what I needed so it really cut out a lot of the guess work. Problem was I usually didn't have my computer with me so I kept forgetting to use it. Now that I bring one with me most of the time for my RS and carry a smart phone which could probably handle it too it may be time to bring it back.
Care to share that spreadsheet? Sounds pretty cool.
SteveL is offline   Reply With Quote
Old 02-04-2010, 05:27 PM   #8423
It will be different for different front ends so I will share with you the method and formula I used.
First measure the distance from the bottom of the chassis to the center line of the front axle. We'll call this X.
Next measure the distance from the bottom of the chassis to the center line of the 0 ride height adapter. We'll call this Y.
Additional values:
Front ride Height = FH
Rear ride height = RH
Front ride height Adapter = FA
Rear ride height Adapter = RA
Front wheel Diameter = FD
Rear wheel Diameter = RD
So then front ride height is:
FH = FD/2-X-FA
And rear ride height is:
RH-RD/2-Y-RA
That's just off the top of my head while I'm still at work...it might need a little tweaking...it might be +RA at the rear since the adapter moves the axle down instead of up depending on the size of your rear tires.
Old 02-04-2010, 07:40 PM   #8424
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by VRacing View Post
Are you talking about Chris Moore's avatar posted right above you or the latest revelations of Jason's R&D efforts?
definately the latest r&d developments jason is working on
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-04-2010, 09:17 PM   #8425
EricF's Avatar
Well let me know, I'll be sure to be there to get in the way.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 02-04-2010, 09:44 PM   #8426
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I've seen more discussion about the R5 to imperial spacing front end on here than anywhere else so I suppose this is as good a place as any to ask this.
I have all the parts to put an R5 front end on an old AE spaced chassis. The only thing I can't find are the 8-32 screws short enough to mount them to the chassis without bottoming out in the hyperdrive adapters. I found the Lunsfurd //Ti screws, but they're shortest length is 7/16ths. Short of ordering 50 through McMaster does anyone have a lead on 8-32 screws short enough to do the job? I refuse to use aluminum . . .Maybe I just need to dremel down a steel one?
Old 02-05-2010, 06:44 AM   #8427
I just put a nut onto some old ally ones and cut them with a dremel. Then take the nut back off the clean the thread and haven't had any problems.
Jason
jasonb is offline   Reply With Quote
Old 02-05-2010, 06:56 AM   #8428
Moderator
Clegg's Avatar
Yep I run the stock IRS alloy screws, just cut down to like 10mm or so. I do actually need two sets, one longer and one shorter so I can adjust ride height over the full range of a full front tire to a trued and run one.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 02-05-2010, 07:34 AM   #8429
avs
avs's Avatar
http://www.tonysscrews.com/category.sc?categoryId=23
high quality steel screws. i tried cutting down aluminum ones and just so of gave up trying to find one length that would work over a range of tire diameters. the hyperdrive adapters have a fastener interference challenge in the rear attachment.
Tony Shimko
avs is offline   Reply With Quote
Old 02-05-2010, 08:31 AM   #8430
E
I think its usually the other way around, but I'll let you know.
Could be that the new front end Jason is working on will be as good or better and not require all the workarounds.
Sponsered by:
NEW IN BOX BMI DB12R bigb11 R/C Items: For Sale/Trade 47 10-09-2008 04:36 PM
-BMI DB12R- joey R/C Items: For Sale/Trade 11 05-18-2008 09:25 PM
BMI DB12R wallstreet R/C Items: For Sale/Trade 17 02-15-2008 05:04 PM
BMI DB12R D-Bizzle R/C Items: For Sale/Trade 2 12-21-2007 03:48 PM
WTB BMI DB12R chris moore R/C Items: Wanted to Buy 8 06-29-2007 06:25 PM
