Serpent to 1/10th EP Touring Kit S400
#526
1) the steel spool drive cups
2) Steel drive shafts
3) Steel turnbuckles
4) diff balls?- they seem to be steel
5) hinge pins-
Maybe for 19T and Stock they can come up w/ aluminum drive shafts, drive cups? For mod, its probably best to keep the steel spool drive cups and axles/bones...
They have already released ceramic diff balls which will help a bit. THe only thing I'd change is the turnbuckles...why didnt they include some Ti turnbuckles?
#527
Its really not heavy at all. It depends of what cells you use and your electronics. THe only "heavy" parts on the car are:
5) hinge pins-
5) hinge pins-
I think some aftermarket brands must preparing to release option parts for it.
#528
The cars worked really well at iic. We were very pleased with results and the rubber car was exceptional. I am sure we will have Billys setup posted shortly.
#529
congratulations!!!! to the team w/the results at the IIC in vegas.
#530
1st practice from Greece.
http://www.youtube.com/watch?v=GoTJ959NX1Y
Please turn off your speakers...Nitro there
#531
How much weight on S400 with 6 cells, Bl/Br, please?
#532
S400 can use how many max teeth spur gear ?
#533
stock car, 6 cell, mohawk lite, GTX, 19 turn, foam old Rim Jaco 57.5mm, on the scale 1448
#535
#536
With rubber tyres race ready with transponder mine weighs 1460g
Cheers, Mark.
Cheers, Mark.
#537
#538
#539
I don't find the car heavy - I tested the Tamiya TRF 415 a couple of years ago and it weighed 872g without tyres and battery - the S400 weighs 850g, also without tyres and battery (with the same electronics).
Ok compared to the Xray FK 04 I tested in the same review, the S400 is heavier, the FK 04 weighed a tiny 815g!!!! But I ended up having to put almost 100g of lead onto the chassis!
Cheers, Mark.
#540
that was wt at tech at iic. with transponder. Also one note that is with the thick chassis so I gues the car was not totally stock
