XX-4 Forum
#1426
Super Moderator
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 76 (100%+)
Thanks for the quick replies guys, i do have other shocks lying around but i do know that the losi xx4 rear shocks have longer shock shaft? The rear shocks from other brands tend to be a tad shorter...
#1427
Guys I'm on the verge on buying one of these cars.
I already have some losi shocks that I can put on it. Lucky me!
Another 4wd buggy to add to the fleet.
One small problem, can you still get parts for this car?
Or will XXX-4 parts fit straight on mainly the A-arms is all I'm worried about
because it has aluminum bulkheads on it?
I dont want to get it knowing I cant get parts.
I do plan on racing it in the 13.5 4wd class, because I already have 2 built
for modified.
for modified.
#1428
Tons of parts on losipartshouse.com other places as well. I am pretty sure the xxx4 rear arms are the same. I think the fronts are different but i'm not sure. you can get almost every part.
crazy fun car.
no pressure ;-)
crazy fun car.
no pressure ;-)
#1431
I'm hoping to have Wilson's old XX-4 soon.
I bought some parts for the XX-4 while I was at the track last time.
I found some rear losi shocks all I needed was some springs & o-ring shock bladder replacements. Bought a bumper set, 78 tooth spur, 25 tooth pinion
both of them are losi brand. I have a slider motor, digital servo, 2.4 Ghz radio & esc that I might put in the car, just to have the car 100% Losi for a while.
When I sold the slider a couple months ago I kept all the electrical stuff.
Never used the motor or esc. I heard they were good I just never put power to them.
Maybe they will find thier way in the XX-4.
#1433
My XX4 with LiPo saddle
I try to do my best to get this result
#1436
THAT IS THE CLEANEST XX4 I HAVE EVER SEEN!!!!!!!!!!!!!!!!!!
#1438
Oliver...awesome. Love the little touches, the electronics plate, the tunnel cover being machined down with the antenna tube mounted on it...the little machined bits on the front arms, replaceable rear skid pad and rear toe block.
I could only strive to have a car 1/2 as well put together as that.
#1440
AE Is Killer Of All......
Oliver my friend that XX4 is clean ... Awesome
