Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 06-28-2016, 10:35 AM
  #976
Finalist's Avatar
Originally Posted by Rhett McNair
Predator body is up on Proline''s site
http://www.prolineracing.com/bodies/...-clear-body-b6
I'm not sure about that design for the way you have to cut the body to allow the lay down slipper nut to stick out. Seems like a better design could have been molded to cover all of the lay down like the stock body.
Finalist is offline
Old 06-28-2016, 10:36 AM
  #977
Finalist's Avatar
Originally Posted by boucher
I think they could have done a better job covering the spur gear on the laydown gearbox.
Beat me to that post.
I love the Predator design on the b5m, but tfor the b6 I'll pass.
Finalist is offline
Old 06-28-2016, 10:37 AM
  #978
BRSracing's Avatar
Trader Rating: 67 (100%+)
good for carpet i guess not so much for dirt.
BRSracing is offline
Old 06-28-2016, 10:43 AM
  #979
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
The B6 body actually looks pretty decent.
Wildcat1971 is offline
Old 06-28-2016, 10:46 AM
  #980
Originally Posted by Kody Numedahl‎
Sorry for the confusion in the manual about the shock eyelets. Either eyelet can be used on either car but I made a chart to explain when to use which eyelet. Having the two different length eyelets allows for proper down-travel/up-travel when shock locations are changed.
GonzoKY is offline
  #981
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Originally Posted by GonzoKY
wiki/front page stuff for sure.
RC*PHREAK is offline
Old 06-28-2016, 11:04 AM
  #982
PW
PW's Avatar
The JConcepts S2 body will be released next week, and the spur gear will be covered
PW is offline
Old 06-28-2016, 11:06 AM
  #983
Ugh. I keep refreshing the JC website hoping to see them =P
boucher is offline
Old 06-28-2016, 11:32 AM
  #984
Does anyone know if 25gr C brass arm mount asc91690 can be mounted in B6D configuration?. It appears only as B6 laydown car option parts in Team Associated webpage.
The reason maybe there are not enough space with B6D trans motor plate.....???
Raulote is offline
Old 06-28-2016, 11:35 AM
  #985
Jack Smash's Avatar
Trader Rating: 35 (100%+)
It looks like the predator body was cut for the standup tranny and shown with a laydown.
Jack Smash is offline
Old 06-28-2016, 11:40 AM
  #986
looks like that is laydown only
Old 06-28-2016, 11:46 AM
  #987
Jmuck69's Avatar
Trader Rating: 14 (100%+)
I was thinking the same thing. It would be nice to have the extra weight there.
Jmuck69 is offline
Old 06-28-2016, 11:50 AM
  #988
It is probably a space issue. maybe someone will make a steel one.
Old 06-28-2016, 01:35 PM
  #989
ray_munday's Avatar
I spoke with Kody and it doesn't fit the stand up gearbox. I received my kits yesterday and have the 12g brass c. Will be testing outdoors this weekend.
Ray
ray_munday is offline
Old 06-28-2016, 04:58 PM
  #990
Trader Rating: 15 (100%+)
I ordered kashima shock bodies for my b6d. Don't have either yet, but just discovered that the rears are supposed to be 27.5 mm (same as truck fronts) instead of the 31mm that fit the b5m. Bummer, because I ordered what fit the b5m. Had no idea they changed the shock body length and I feel like I've read plenty on this car already. At least they both take the same shafts from what I can tell in the manuals. Just a little warning for those that are looking to get the kashima shock bodies. You will have to run the optional 91666 rear shock tower with the 31mm shock bodies.
mx836 is offline
