Team Associated B6 & B6D thread
#6196
Can you post a photo? Curious about electronics layout. Did you make those 2 changes together or independently? Which one gave you a bigger change?
Also, how much stroke did you take out going from outer to center hole on front shock?
I haven't. I lowered rear ball stud, went to the silver front spring and 32f/30r oil and I'm really close now. Super easy to drive, just 5% "safer" than it needs to be. 2nd qualifier coming up. I'm 8th out of 25 (that's with a 27sec lap on an 18sec/lap track), which is better than I've been lately.
#6197
Yep, lots of JC being run there, but anything clay compound works. I've tried a few combinations (AKA, Losi, JC) and they're all about the same with this car so far, but I don't have any PL's so maybe that's worth a go.
There's a kid who also runs a standup B6 and he's really fast (TQ'd stock when all the good guys were there). Our setups look really similar but he drives with his brakes a lot. My 22 3.0 had plenty of steering and the B5's did too. Not sure what to do here.
Things I've changed from stock, in case anybody has some ideas:
+1 steering arms
1mm ackerman spacer (stock is 2mm)
+1mm caster hat bushings (stock is 0mm)
Front shock in middle of arm w/2mm limiter (stock is outer, no limiters)
2* anti-squat (stock is 1*)
30f/27.5r shock oil (stock is 30/30, common is 32.5/30)
Battery in the middle, moved forward didn't seem to change much.
Tonight I think I'll take out 1mm of ball stud height in the rear to try to get it to come around more, and maybe go back to heavier 32.5/30, that change was to try for more fore/aft weight transfer. May also try the heaiver front spring, though I'm not optimistic for that without the lay-down, which I won't try until I'm confident in the setup I have.
This car is about the least sensitive to adjustment of anything I've ever run so I'm not afraid to mess around with it between runs. Got that going for me, I guess..
+1 steering arms
Green yokomo rear, white ae front. shock oil similar to yours. I should really generate a set up sheet.
rear hubs in forward position as well i think really helped a lot. I also went with a "narrow" width on the arms with the 3*toe/ 2* anti
also consider 21 mm front droop, 27 rear droop. Droop has tremendous impact on steering be it on power or off power.
#6198
Changing to the middle hole, I added 2x of the thin black spacers to limit droop..
Radioctrlhead, when you say "droop", do you mean shock stroke (length of exposed shock shaft at full extension)?
#6199
R/C Tech Elite Member
I tried the lower ball stud before changing the shocks. I'd say both changes had equal impact but I was a touch too soft before.
You dont need the prefabed shims, there just easier to put in. You could
experiment with washers just as easy.
#6200
You can run a 84 tooth spur gear on this car and still be able to use the gear cover.
I tried a 87 and its just too large. It rubs against the rear turnbuckles and gear cover wont fit.
#6201
Hey JSK, I am ordering weights to have for tuning like we talked about yesterday. Have u ever added weight in the rear? I was thinking I'd get the 12g c and d blocks which would be 24g then I could add the 24g servo plate which is 48g total. Or would I be better off keeping the weight under the lipo and up front?
#6202
Definitely considering it. I really like the stability the suspension has now, accelerates straight, jumps great, handles crooked take-off's/landings (wow, sound's like I suck...) really well so I don't think I want to mess with shock angles to free up the rear or tighten the front. My track has the Schelle shims so if I do it, I think I'll get them. Washers are easy, but I think they could weaken support for the front pivot. As far as I drive to go racing, saving a DNF is worth a few bucks to me.
#6205
The B6 is so lite that I don't think that the weight is an issue. It is most definitely heavier than the stock stuff. The unit is solid. It won't bend. They are very popular. I lost one because I had a bad ti screw break off inside. If you need it, its a worthwhile purchase. If you don't need it, its money well spent compared to other stuff you could be buying [for your RC].
#6206
Tech Legend
I'll keep that in mind here.
#6207
#6209
Standard servo get more couple for less $$
adding weight in the front
#6210
Hey guys for those wanting front bulkhead shims checkout bezerk Rc. He does really nice carbon fibre ones on 0.5 & 1mm. They are great and he ships everywhere. Goggle it
