Hot Bodies D413 1/10 4WD Buggy
#7021
Was thinking there was an HB 2wd in the works, maybe there is...
Any info's Ty or Torrance?
#7023
Looking at the Reedy setup which HB springs are equal to XGear Yellow (F) & White (R)?
Going to put in a bit of a tuning parts order and need to know which springs to grab up.
#7025
Hi everyone,
which tire traction additive do you use on compact dirt (USA track style)?
Thanks in advance,
G-rem
Thanks in advance,
G-rem
#7026
I'll be running 6.5 and as soon as shorties are available i will be getting some Orion packs. ordered some SMC shorties but they're on backorder also.
#7027
Anyone have a roller or an extra roller they would wanna part with?
#7028
#7029
My car was really off ballance on scales set up with the standard shorty set up. I redid the car with the servo on the left and the speedo on the left rear with 14 g. Of weight on the right front and now the car is very close to being equal left to right (withinin 5g.), and its 200g. Heavier in the rear over the front. The cross weight was off by 100g. Before I made the changes and now its even.
I have not driven it like this yet but I have high hopes the car will be even better.
#7031
Don't know if this has been posted before, but for those of you who are cheap like me and don't want to fork out the $ for an upgraded steering rack, here's what I did: Grabbed a couple standard 4X8X3 bearings I had kickin' around. Drilled out the bushing holes in the rack to accept the bearings. Slipped the bearings in with a .5 mm spacer on top and bolted it back together. Result is just about zero steering slop.
#7032
#7033
#7035
