Xray XB4 thread
#2476
Here is the first few laps of my Xray Xb4 buggy running Nosram 6.5t, Nosram esc, Nosram 5600 55c/110c on Proline at Knox Offroad today.
http://youtu.be/RaSFet6-BVY
#2478
Ahh, I thought it might be that(stock racing). I'm so glad that every single offroad class in my area is open (mod). I race a lot of 17.5 blinky touring car, but I can't imagine racing 4WD Buggy with a 17.5. Heck, I added some boost and turbo to my 6.5 because it felt a bit too slow without any timing.
There's no problem with the XB4 spur. The problem is people are trying to race 4wd buggy with crawler motors.
#2480
Well after my first couple of packs through the buggy, really enjoy driving it hard, have a small concern running 6.5t and 5600 55/110 batteries with no boost or timing changes on the nosram gear and that is the motor seems to be getting hot after about 7 minutes hard running.
Im running the stock spur with a 19 pinion pretty much on tracks like the video on the last page, diffs are 7k front and 5k rear, should I be going up or down a tooth in the pinion to perhaps reduce the motor heating up ???
#2481
We've been running 20 and 21 pinions on tracks of similar size with a 6.5T Tekin Redline Gen2 and RS Pro.
19 was the first we tried 6 months ago but was way under geared and ran warm with our setup.
So I would definitely go up at least 1 tooth for outdoors
Bent
#2482
Just built my kit last evening. This was Far and Away the most impressive kit I've ever built. Everything fit absolutely perfectly. The components are the highest of quality and I've never seen better instructions in my life. If this thing drives as good as it's built, I'm going to be very happy!
One question though, how are you guys wiring your esc to battery connections to avoid the spur gear eating the wires? I think I may need to create a custom set of wires of my saddle pack and shorten the battery wires from my ESC. On my B44.2 I made a spur guard out of lexan, but on that car the spur only protrudes above the deck 5 millimeters or so. The XBR spur sits above the deck quite a ways.
#2483
Bent
#2484
savagesam, do you have a good fan blowing on your motor?
I'm geared around the same as you (84/20 compared to your 81/19), but my motor is only a little warm after a 6 minute race. My ESC (orion r10) is usually warmer than the motor (ReVtech 6.5). I do have a fairly smooth trigger finger from racing mod TC though. Maybe the small amount of boost I have could be helping the motor to run more efficiently as well. More rip out of less throttle? I don't know. works for me
Anyway, it's an awesome car. I've been having a blast racing my XB4. The only thing I would change, would be making the wing mounts a bit more reinforced at the back, but ever since I've been shoegooing an extra piece of lexan under the center of the wing, I haven't snapped the back off any mounts. I broke a few before doing that though.
Wease, I run all my motor wires and one battery wire under the front drive shaft. It's a small channel there, but they all fit. Nothing is close to touching the spur on my car. It probably helps that I'm using a low profile servo.
#2485
Here is my wiring set up, as you can see I built a little cover for the servo wire and speedy wire to the receiver, also running the smaller servo gives you more room, Im not running a fan on the motor side but have been told its a good idea, would like to see some pics of how people are running a fan on the motor side
#2486
We race here in Perth in some very hot conditions with the combo you are using and the same gearing and never more than 8 blinks for motor temp after 5 min race and 2 min warmup.
