Hyper TT 4wd 1/10th Truggy Thread
#3481
#3482
My sons TT is just way to rigid on the track bobs and bounces everywhere. What options are there for softer springs.
Track type outdoor dusty gravely at times hard packed. So soft tyres are essential but the springs need to be changed as well
Anyone suggest rims tyres combo and softer springs ?
How do you upgrade to 17mm hubs ?
Cheerz ROF
Cheerz ROF
#3483
Anyone know what the screws that hold the wing on are called, My wing popped off my hyper TT
#3484
It happened to me i hit a 2inch high spot on the side walk and it just went rolling off its all good it gave me a reason to buy the cva's
#3485
Cheerz ROF
Cheerz ROF
#3488
i have to agree with mkiiina stock springs are awesome you might try lowering the weight of the shock oil
#3491
drop the weight of the shock oil
#3492
I just bought myself a hyper tt from here with mmp and novak 6.5t hv. how do the novak campare to castle or other motors. Should I sell the novak and purchase another motor? I am crazy for speed and torque. I will probably be getting a gen ace or sky 4s 5000mah lipo for it. I am still in building process fyi.
will the drivetrain handle these?
http://www.ebay.com/itm/Proline-1173...ht_1911wt_1037
#3493
What is wrong??
Ok so here is my Hyper TT and it is running kinda weird. Here is a vid.
It has a Speed Passion GT PRO 2.0 ESC and a
Tekin SC4X 4.5T 550 motor a Savox 1258 servo. My problem is that the boost function is not kicking like it should.
As you can tell from the video I am holding it at full throttle and it kicks into boost after a few seconds. I tried a new sensor wire and will be changing out the motor to a Novak Ballistic 4.5 550 to see if it helps. I am also running the current firmware on the ESC and the settings are the ones from Speed Passions website for the SCTE Losi truck. I tried a new sensor cable and it still does the same thing. As you can see in the vid it is cutting out right before the boost kicks in.
Setup I am using http://www.speedpassion.net/uploadfi...20Walt%20G.jpg
Am I pushing the ESC too hard with the 4.5??
If you have any thoughts please let me know.
+ YouTube Video | |
#3494
#3495
Hyper TT with SC Kyosho DRT body, Traxxas front body mount, Losi SC wheels and tires. Used the wing mount as rear body mount, same chassis and all.
[IMG][/IMG]
[IMG][/IMG]
