TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck
#151
TLR332067 - Team Losi Racing Complete 2wd GEAR DIFF, Aluminum: ALL 22
A member of the 22 Empire facebook group measured the above diff, ball diff and the Serpent gear diff and as it turned out, the planetary gear diff is approx. 0.6 mm shorter than the ball diff. It was mentioned that TLR was working on longer outdrives to fix the issue, but I think the problem can be solved with a couple of washers. Of course, experiencing such a failure during the first battery pack was a bummer, but as long as teething problems can be fixed, I am ok with it. I am neither a sponsored driver nor a TLR fanboy, and I am convinced this is the best ST option available right now. The first couple of laps were very promising!
The LOSA2954 diff is a standard bevel gear diff that was originally designed for the RTR vehicles when many people did not consider gear diffs an option for racing kits; I remember a picture of Mike Truhe who seemed to be shocked by the notion of using a gear diff at an EOS race. (report on oOple)
This cheaper diff has been a very tight fit from the 3.0 generation and can have leaking issues with the standard O-rings and can become warped if not assembled correctly. People started to use the Serpent diff for all these reasons. The TLR diff is a planetary gear diff, which works differently and requires thicker oils than a bevel gear diff. I used 15,000 cst Yokomo oil in mine on a tight carpet track and I liked it very much; in my YZ-2 I would probably have used 3,000 to 5,000 cst with all spider gears or 5,000 to 7,000 cst with two spider gears.
#152
My bones are close to the edge of the out drives but i have not had any issues. Also running a ball diff. Was thinking about possibly shimming the drivesahft out further from the hub but that will change some handling characteristics which might not be for the good. The longer driveshaft will as well but it might be a more positive change. This is the first i have heard of someone having an issue as well. Did you doable check that everything was assembled properly?
#153
Just send him your blank chassis and he'll make a custom protector for it:
Chassis Protectors : Dutch Oven Designs
#154
3.0 body on 4.0
I just salvaged my 3.0 body to fit. I removed 12mm from front of rear wheel wells to clear front mounted shocks. Put the 3.0 rear body mount on front of 4.0 shock tower so that body posts are in the pickup bed of body. Doing so pulls out the posts so I used the wing angle adjustment shim to pull them back into position. A little bit of body needs to be removed on sides at the shock bleeder screw to clear the top of the shocks. This will have to do until I get the 4.0 body painted.
#155
Any other bodies fit on this truck?? Not a fan of the stock body.
#157
One other question since you mentioned the HRC block. If running a brass block and 25 deg kick does the spacer still go between the block and chassis? Or does removing the spacer make the brass block HRC? I haven't been able to find a solid answer...... probably haven't looked in the right place yet! LOL
#160
Thanks!
#162
is there a rear sway bar for this truck ? if so could you post the part #. I can find anything listed.
#163
Anyone have issues with the front wheels hitting the suspension arm right where it flares out?
I noticed the 4.0 kit setup is 2mm trail and short VLA. But when I tried that combination on my 3.0, the wheels would rub the arm right where the philips screwdriver is pointing at. I actually dremeled it down a bit to clear, but eventually just gave up and went back to 3mm trail.
T4.0 arm on bottom, T3.0 arm on top. Part looks exactly the same, except where I dremeled it down a bit.
#165
I am now able to run the 3mm trail setting with no rubbing, but 4mm still has too much rubbing and is unusable for me.
