TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree139Likes
Old 12-21-2017, 07:43 AM
  #121
tazz888's Avatar
Trader Rating: 26 (100%+)
Originally Posted by kaistas
Finally got mine out to a track last night. Settled on 78/22 for gearing on astroturf. Was still worried that the rear shafts would pop out of the cup (See earlier pictures), but they stayed planted all night long, even off of some bigger jumps. I did break one of the turnbuckle arms though, so my night was cut short, but so far I'm very happy with how it handles on a high grip surface.
I picked up a pair of 94mm bones TLR232032 just to have a little more of the pin engaged in the outdrive.
tazz888 is offline
Old 12-23-2017, 12:44 PM
  #122
Is it worth upgrading to the 4.0 from a 3.0 with the laydown conversion?
TRIPLE 675 is offline
Old 12-23-2017, 07:29 PM
  #123
That's a loaded question. A debate I keep having with myself. What to do. I believe upgrading to all the 4.0 parts is way too expensive. Better to sell 3.0 and then buy 4.0.
But, I have the 3.0 as well with laydown. Another option is to order the 4.0 upright tranny shock tower to bolt right to the 3.0 laydown. Then you can order the 4.0 shock bodies and shafts and you have the 4.0 geometry for the rear for 50 bucks. The 4.0 chassis is 2 mm longer but I run on a tight indoor track so not worried about that.
WallyRC is offline
Old 12-23-2017, 10:24 PM
  #124
Won't you have to buy the new body then?
faqcya is offline
Old 12-24-2017, 01:30 AM
  #125
No. You can put the body/wing mount on the tower and use the same 3.0 holes.
WallyRC is offline
Old 12-24-2017, 02:23 AM
  #126
Doesn't the 4.0 come with stiffezel arms and the 3.0 doesn't?
faqcya is offline
Old 12-24-2017, 06:26 AM
  #127
Wow, I didnít think there was that much of a difference. I was under the assumption the new truck was mainly just focused on a laydown tranny with an updated chassis.
Old 12-24-2017, 09:51 AM
  #128
Trader Rating: 14 (100%+)
Ran Friday night and have to say it was very promising. Im normally a mid to back pack sportsman buggy guy since I dont get to the track much and I was P2 after first round and P3 after the 2nd. In the main I came onto the front straight at the end of the first lap in dead last and worked my way back to 4th. The only guy that had a faster hero lap was running a 7.5 I think where most of us were running 13.5's. Man I miss ST!
DG Designs is offline
Old 12-24-2017, 03:59 PM
  #129
I believe you are correct.
WallyRC is offline
Old 12-25-2017, 01:38 AM
  #130
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
Hi guys, just finished building my 4.0T tonight just need to set up my esc and hopefully get to drive it early next week. I built my kit with JP's setup thats posted on the TLR blog page and will post my results with it after the first outing. I race at SDRC raceway which is a medium bite indoor clay track and will be running in the mod class and plan on being more active on here. Frank does a great job answering questions on here but I will do my best to help out as well and post some setup tips that i run across with the truck.
Merry Christmas everyone!
Eli is offline
Old 12-25-2017, 10:55 AM
  #131
Good to hear. What gearing were you runnin.
Thx
WallyRC is offline
Old 12-25-2017, 11:09 AM
  #132
Suspended
Even after doing all that you are still left with the rear shocks and tower behind the rear axles. Moving all that weight forward is where the 4.0 is still going to have the advantage. You could do something like the Xfactory mod to move the shocks forward, but that mod is just a bandaid fix.
urnotevenwrg2 is offline
Old 12-25-2017, 07:52 PM
  #133
Thx
78/23 with the new Reedy (yeah I know)
Old 12-25-2017, 07:53 PM
  #134
Thank Eli!
Old 12-26-2017, 10:39 PM
  #135
You are probably right. I already moved my shocks to the front on my 3.0. Just flipped the arms from left to right and vice Versa. Spaced the shocks forward and geometry looks good. But the pressure is still behind axel like you mentioned with the tower. I like the idea of the lower COG with the shorter shocks so I will probably order the 4.0 rear tower and shocks to try. Gonna see how she handles with the shocks in front next week first before I do. I think the 4.0 full set up will really benefit carpet/turf and hoping my pseudo 4.0 rear end will suffice on clay. Time will tell. Will keep you updated.
WallyRC is offline
