TLR 22T 4.0 Race Kit: 1/10 2WD Stadium Truck >
Like Tree136Likes
Old 01-12-2018, 07:48 AM
  #166
RazorRC's Avatar
Originally Posted by jmitchell
Yes, this happened on my 22T 4.0 truck with 3mm and 4mm of trail. But not with 2mm of trail. I filed down my arm in the same area and also trimmed off a little on the inside edge of the wheel.
I am now able to run the 3mm trail setting with no rubbing, but 4mm still has too much rubbing and is unusable for me.
Interesting... is this with short or long VLA?
RazorRC is offline
Old 01-12-2018, 11:05 AM
  #167
Originally Posted by RazorRC
Anyone have issues with the front wheels hitting the suspension arm right where it flares out?
I noticed the 4.0 kit setup is 2mm trail and short VLA. But when I tried that combination on my 3.0, the wheels would rub the arm right where the philips screwdriver is pointing at. I actually dremeled it down a bit to clear, but eventually just gave up and went back to 3mm trail.
T4.0 arm on bottom, T3.0 arm on top. Part looks exactly the same, except where I dremeled it down a bit.
If you try 3mm under castor and 1mm on top instead of 2/2, does that help clearance. Noticed a couple set ups that way. May bring the wider part of rim lower. Suppose to increase on power steering and out of corner. May help??
WallyRC is offline
Old 01-13-2018, 08:18 AM
  #168
Short, but I don't think it would matter if it was short or long. The interference is significant without removing any material from the arm. At 4mm of trail my wheels were locked up and difficult to turn by hand.
Any yes moving the caster spacers helped but not completely. I still had to trim off material to get the 3mm trail to work.
jmitchell is offline
Old 01-16-2018, 03:29 PM
  #169
Ran my 3.0T truck today. Indoor clay. On clay primes. Changed front castor blocks to 0 degree. What a huge difference for me. Didn't lose any of my turn in but gained mid corner and exit steering. On power steering was so much better. Had the same setup in my old durangoes. Increased camber to 2 degrees in front because was traction rolling from less camber gain on compression. Was running 1 degree before.
Running 13.5: 78/24 felt really good.
WallyRC is offline
Old 01-19-2018, 06:14 PM
  #170
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Hey guys, I need a good setup sheet, im getting back in and I want to have my sons truck hooked up, that will keep him interested, and me RACING, ...so im ordering 2 kits tonight, 6.5 motors, esc/have all that covered, he will run a 8.5 maybe ill see, but its only indoor, hard red clay, run slicks w/additive, no outdoor, well run Nitro for that, just would like to order whats the basic stuff that gets changed off the bat, sorry glasses broke, and for my 40th b day, I started needing them, even with this damm 27" IMac screen!!! Kyosho springs? SCHELLE Diff?? oils, and building parts, like high bite clay indoor, im sure theres a goto castor block etc, thanks guys....appreciate it, im gonna back read as much as ii can, its already fuzzy "the screen"
TommyBlazin is offline
Old 01-20-2018, 06:58 AM
  #171
6.5 IMO is way overkill. 8.5 it strong enough and will still overpower most surfaces. if you need more power on longer stretches a little boost or turbo will get ya.
freebird is offline
Old 01-20-2018, 08:21 AM
  #172
Default Ride height
I am going to drive this truck on carpet. I can't get the ride height under 26-30mm. I'm looking to get to 17mm. Any suggestions? I'm pretty new to the hobby and did some research but adjusting the springs all the way out didn't help, but it seems like I want stiff springs. Not sure.
prodigyweb is offline
Old 01-20-2018, 08:24 AM
  #173
Default Ride height
I am trying to lower my ride height while keeping my spring stiff. I feel like I'm missing something in the understanding. I've read a few articles online and I have my springs all the way out and the ride height is still 26-27mm.
Surface will be carpet so I think I want 17-19mm? Any thoughts.
Old 01-20-2018, 11:28 AM
  #174
Try the lower spring or standard spring cups. Believe the +4 come with the kit. I have also read that people are using AE cups that are even more shallow.
WallyRC is offline
Old 01-20-2018, 11:33 AM
  #175
I have the 3.0T but the setup out of the box for the 4.0 should be close for what you are looking for. Stock springs are good.
I have bent and broke a couple camber links. I would go with some Lunsford replacements.
Front aluminum TLR camber block.
TLR or Exotek servo mount so you can mount the servo behind if you want.
Pick up extra front spindle parts.
I also agree with power. I run 8.5 and have my son run 13.5. Plenty of power.
Good luck and have fun.
WallyRC is offline
Old 01-20-2018, 03:34 PM
  #176
I only have the 22 4.0 SR buggy, but when I looked into this Yokomo Yatabe Arena springs were an option as well. The springs are slightly shorter. Also if you haven't run the truck yet the springs will settle a little bit.
Edit: Guess my point is can you use shorter springs meant for a different car that are the same\similar stiffness?
Ffejrey is offline
Old 01-21-2018, 09:30 PM
  #177
Ok. I'll give it a few practice rounds and recheck.
Old 01-22-2018, 07:32 PM
  #178
moto44's Avatar
Trader Rating: 9 (91%+)
Having some issues with the front axles pulling out of front spindle. Has anybody found a cure for this problem?
moto44 is offline
Old 01-22-2018, 07:40 PM
  #179
Super glue the insert in place. They do have an aluminum insert option but they are on back order.
faqcya is offline
Old 01-22-2018, 08:21 PM
  #180
Eli
Eli's Avatar
Trader Rating: 15 (100%+)
I started with JR Mitch's setup on the tlracing.com website under their blog page. Truck feels amazing. I did end up making a few changes, ended up taping in an orion 3800 pack about 2mm off of the waterfall, going down a spring rate to the white spring in the rear (kit front spring) and running the 3 hole 1.4 plus 1 hole 1.0mm pistons all the way around with 35/30 TLR oil.
Eli is offline
