Team Durango DEX410
#661
hmm...i dont have any issues over rotating into the turns, its power-on exiting where this is no grip.
I have run 4k F / 2k R in the diffs up to 10k F / 10k R and was actually struggling to get steering from 10k in the front, a bit worried that 50k front will turn it into an understeering monster
im trying to take it away lol
#662
Ok so i have purchased a second hand Darango, Now reading the forum looks like i need tc5 ball studs 3x8mm and 3x10mm with long shank RPM ball ends for piece of mind.... And also I have searched for these o'ring from Kyosho but cant find the ones but some say the X ring from Darango wont leak with Green slime... I'll follow the tips and lightly sand the cups before i reassemble the diffs has any one tryed a sealant on the diffs and gear ??
Any thing else before i do a rebuild.....
#664
Deciding electronics!! Please help
:::sorry, double post:::
#665
Hello guys
Has any one of you guys tried to squeez SP GT2.0 Pro Brushless ESC and Futaba 604FS in the Rango with success?
How much vertical clearance under front drive shaft?
Thank you in advance for the input.
Cheers,
Bob
Cheers,
Bob
#667
Got them here at CBC or any place that can sell seals,i only paid $4
for mine but they have to be viton oring there a harder oring
thean STD oring's.
If you can find some shim that fit say 7x5mm that are very thin
that fit over the 5mm shaft between the oring and metal washer
under the eclip will help with putting a little bit pressure on the oring.
Car has only had 6 runs so far but time will tell for $4 it is worth a try.
Cheers Jay
thean STD oring's.
Cheers Jay
#668
Ive got a Tekin Rs and Spektrum sr300 and the receiver is sitting
on it's side and they just fit.
Try putting it in different way's even if you have to put the ESC on
it's side or the receiver.
Ive seen big ESC's in these but they are using micro receiver's.
No to sure but i think Retro-Rc is using Speed Passion send him PM.
Im sure other's are using these ESC's in they Durango's
Jay
#669
Once I start racing again (hopefully later in the year) I plan on replacing all the electronics with something smaller.
AH
#670
Thanks a lot Jay,AH
I have seen many people in this thread using SP identical ESC, but not much of Futaba user.
After I went through all pages in this thread, I found someone mentioned about Oople forum.
w w w.oople.com/forums/showthread.php?t=31939&page=8
Bingo, SP GT2.0 + Futaba receiver!!!!!! Worth mention this page again as there'll be more update pic, sooner or later.
Now, I wonder? Will this layout survive thermal in extremely warm weather in Thailand?
Bob
Bob
#672
#673
Thanks a lot Jay,AH
Bob
Bob
the temp is.
Jay
