Team Durango DEX410
#646
Good to hear they are doing that. Can we assume that the aussie distributor will be honouring this too?
I haven't had any issues with drive pins but i'd like to upgrade just for peace of mind.
How is everyone going with setups? I must admit I am struggling with my car somewhat - I am having problems getting rear traction, which is somewhat concerning considering the track i run on is a bout 50% astro turf
Has anyone tried adding a lot of weight to the car around the cells? I was thinking of getting the Azarashi Fettera body and undertray so I could line the side of the undertray at the back with weights, to make it feel like it had some nimh cells in there.
#649
Bodies looks cool guys, got mine getting painted as we speak. they definatley are more roomy.
Adding weight does help i added weight to the rear where the mounts are next to the battery and defo helped.
Trick to the rango's are thick diff oils! that will solve your traction problem!
JK
JK
#651
#652
I'm no experts at set-up, but you shouldn't have trouble finding traction at the rear. I'd look at your set-up before adding weight.
Most of the weight is at the front on the Rango. So give the rear more traction with springs, shock position, and work back from there to tune to your driving style.
Also I find with the rango, if the back is over rotating, just throttle up in the corner and it pulls itself into shape.
#657
Exactly what "1"said about not backing off. Compared to other EP 4wd cars ive had the rango loves to be on-power.
If you come into a corner and let go of the trigger the rear will tend to want to over-take and i think its due to the car pivoting onto the front wheels because all of the weight is in front of the centre slipper. If you just keep the throttle on during corners the car loves it and thats why the DEX410 is so much quicker around tracks. Adding weight to the rear helps stabilize the car mid air and exiting corners with traction.
Also id start with front 20,000 diff oil and rear 10,000. The car doesnt change much when you only adjust by small amounts in diffs. I went from 2,000 rear to 10,000 rear and didnt notice any difference really. So i went straight to 20,000 k rear and 50,000k front . This will help the car square up exiting corners and power can be applied much earlier.
JK
JK
#659
hmm...i dont have any issues over rotating into the turns, its power-on exiting where this is no grip.
I have run 4k F / 2k R in the diffs up to 10k F / 10k R and was actually struggling to get steering from 10k in the front, a bit worried that 50k front will turn it into an understeering monster
