Team Durango DEX410
#635
Ok,
i had a few issues with leaky diffs. plenty of green AE slime on X-rings for the diff and no issues. Also tap the gear that goes on the outdrive shaft down about 0.5mm more than standard and helps the swell the X-rings and create a better seal.
My diffs are meets old and no leaks
#636
does any one that details of alternative ballcups that I can use on my durango. I have tried a few and they seem to tight with the standard ballstuds, so the body doesnt freely move.
The stock ball cups are just too soft and push through the thread when I crash.
thanks
HJB
thanks
HJB
#637
as for diff leaks someone posted on the other durango thread on here to use ky00rg-05 o-rings in place of the x-rings. also they said sanding the diff cup w/ fine grit sand paper in a fig. 8 pattern helps seal it to the ring gear. i havent had a chance to try it myself though.
#638
The kyosho reference is from 1/10 nitro on-road cars.
Put them with green slime.
No leak with 2000 asso in the rear diff.
#639
Heres mine, with the Tresrey Gainbull body on it....hated it at first - but it grows on you after a while.
I have some of the kyosho seals to fit - but cant be arsed pulling down the diffs again........they dont leak quickly enough to justify the effort at the moment!!
Cheers
Darryn
Cheers
Darryn
#640
Cheers
Darryn
Cheers
Darryn
Those wheel nuts and some of the pliers aren't VENOM!!!!
#642
Team durango will offer 50% off for 2mm driveshaft.
#644
#645
