Team Durango DEX410
#692
does anyone have a spare front shock tower for the DEX410 for the weekend or i can buy?
PM ME PLEASE, mines cracked. just noticed.
JK
JK
#695
anyone got a good base set up?
i race on hard packed clap that is dust when dry n loamy when wet but with enough laps it groves up nice
cheers Dan
cheers Dan
#696
Type of Materials used between the 2 versions should answer that $300 cost difference question.
#697
#698
Obviously i would get one from venom.
Being friday its not enough time to get one shipped up by sunday.
I did manage to find one for this weekend. Thanks anyway guys.
JK
JK
#699
From what ive researched the differences are as follows:
DEX410R has Aluminium Shock towers,PLastic side guards,Plastic front hubs,plastic bulkheads. But its also benefits are the new upgraded 2mm driveshafts and transponder mounts.
DEX410 has Carbon towers, Aluminium front hubs and bulkheads and side guards.
The 410R will be awesome value for money when it arrives which im pretty sure is not to far away. 410 is still a insane car.
JK
#700
I feel as tho my "current setup"is the best to start with as the car is working on all tracks i put it on at the moment. Im more than happy to share it with you and everyone. Its completely different to box setup. Reason for that is box setup is designed for EURO tracks and is really stiff.
Rear:
Shock Oil: 25
Spring: Silver
(Outer hole at tower, middle hole on arm)
Diff Oil: 20,000 Venom
Hubs: Short wheelbase
Camber link: Outer at hub, inner and 2 up from bottom at tower.
NOTE: Stock shock pistons but had drilled all holes out 0.1mm bigger than kit setup. cant remember if kit setup is 1.3 or 1.4mm holes but mine are 0.1mm bigger than kit.
Front:
Shock oil: 35
Spring: Dark blue
(Outer hole at tower, outer hole on arm)
Diff Oil: 50,000 venom
Hubs: Standard
Camber link: Outer at hub with 2mm shim under ballstud, outer at tower 2 up from bottom.
NOTE: Also drilled kit pistons out by 0.1mm from standard. Refer to manual for kit piston holes front and rear and drill both out by 0.1mm.
I also run the brass weights as an option at the rear. Im running 1.5 degrees of rear camber and 1 at the front with roughly 1.5 degree of toe out at the front. Im running kit toe in at rear.
Goodluck, hope this helps.
JK
#701
DEX410R Now Here!!!
The DEX410R shares the same Team Durango DNA, performance and innovation as the World Championship winning DEX410, but with a more 'regular' specification. If you want true world-class engineering and race winning performance, at a price a new R/C racer can enjoy, you have found it in the Team Durango DEX410R!
Price: $400.00
Please email: [email protected][/email]
#703
The "R" looks great and the price is awesome... Might have to go offroading again!
#704
"R" version have landed
