The Hill Camp Courtney RC Park Okinawa Japan
#2296
Definitely yes on Wed, I just got back from there testing some 28T motors and shaved tires. Sat is probable, and 8 sounds good to me.
#2297
#2298
On another note, I am doing some tube work on a "midnight pumpkin" truggy. Did you ever make any more progress on your willy.
#2299
I have, but not as far as on the cage. Thats really the only thing I need to do so I don't kill the windshield if it rolls over, but it is operational. I should bring it to toguchi and give it a go, and maybe, have better luck than last time. Ill try and get out there wednesday when you all go.
#2300
#2301
Ok, so I'll be at Toguchi around 5-5:30 for Hump Day Crawl.
My Turnigy 9X came in today. Time to get it installed. I already did the battery mod to put in a 9.9v LiFe instead of 8 AA's. Saturday Sailing looks to be a go for me. Possibly the maiden voyage of the I-Phantom. Hopefully the kid's soccer doesn't get in the way.
Brett has offered up his green monster truck to help pull the stand when needed.
Igy....I know a guy that can powder coat that thing when your done with it.
#2302
#2303
SO I started looking into the willy to see what is wrong with it, and the fxr is doing the same thing as my other one is. With it all connected as soon as I give it forward or reverse input it only moves for a second or 2 then cuts off. The fxr in the willy doesn't lock up like the other one though. When it locks up all the lights flash, really bright on the willy and very dim on the jk. On the willy as soon as I let off the forward or reverse input it goes back to its normal flashing lights and I can again get it to move for a second or two before it locks up and all lights flash. Im stumped, as is Tekin they told me they've never heard of this before. Should have stuck with the holmes hobby brxl for the extra $10 oops. Also I have the CC bec wired from the battery directly to the servo not to the RX. Worked great for a while, not so much any more.
#2304
Just found a post on here and it seems if you try to update your fxr to version 030 it jacks it all up and then you have to send it back to tekin to get it fixed. I'm going to call them to find out for sure.
#2305
SO I had a conversation with a guy, Jeremy, at Tekin tech support and he was a little stumped by my problem. He said that the programing issue had been fixed to the best of his knowledge so my newer fxr's should not have any issues in those regards. So, I started trouble shooting a bit more to see what was going on. After going threw each step in the Tekin hotwire one by one I found my lvc was the issue. I had it set to 3, which is not 3v per cell, it is 3s. So I feel a bit stupid, but I learned something new. One don't jump to conclusion, and two learn how to use the products you have. I didn't find anything that tells me the correct way to program it but I may not have looked hard enough. Lesson learned the hard way... kind easy didn't have to dismantle my willy. My only defense, which is thin, is I am mostly new to lipo and definitely new to the fxr. OOPS my bad.
#2306
So now you need to bring that willy back out next Wednesday so we can see it in action.
#2307
What's the cutoff for ESCs without adjustable LVC?
#2308
#2310
I'll be at the marina in the morning....don't know if I will be sailing though. I have to install and setup the radio equipment. I'll bring some electrical tape to seal it up for now. See you guys in the am.
