R1 Wurks brushless motors
#676
Agreed however on a 13.5 R1 V16 , I cant go above 35 degree on the can without the motorlyser screaming over current and shutting down. Motorlyser doesnt have an awnser
#677
Thats because its a bada** motor . try using a 1s battery for better results.
#679
https://cdn.shopify.com/s/files/1/15...30253604338197
If you download the link above it contains many files, one of which is called LCG ESC.pdf that describes the process. I've also included the file I think you are looking for.
#680
Bought an R1 25.5 V16 for the VTA car I built, bought it end of March , was delivered to me on April 1st , Ran it 1 and 1/2 race days , thought I had a bad sensor wire, replaced it .... everything was "ok" to finish the day last Sunday ..... ran it yesterday in practice , ran fine..... then started qualifiying , put the car down and motor started cogging again , no solder bridges , changed the sensor wire again , still cogging ..... finally stopped running, removed it from the car, checked it on my motor checker .... NO sensor lights AT ALL ...... Sensor board is bad . Contacted R1 via their website, supplied them with my proof of purchase ..... was hoping they could send me a replacement sensor board (without me shipping them the motor) ..... I will send them back the bad sensor board if they wish.
5-7 r1 emailed and said they would send me a replacement, thank you R1 , ive had other sensor boards fail too, not just them, but they are taking care of the issue ... cant ask for much better then that
#681
I had a similar thing happen from the above post (twice) Great motor, but suspect durability.....
#682
Same here. Have never had sensor boards go bad before but had two go bad in my R1 25.5T motors. They are fast as hell though so I guess that's the price you pay...
#684
Bought an R1 25.5 V16 for the VTA car I built, bought it end of March , was delivered to me on April 1st , Ran it 1 and 1/2 race days , thought I had a bad sensor wire, replaced it .... everything was "ok" to finish the day last Sunday ..... ran it yesterday in practice , ran fine..... then started qualifiying , put the car down and motor started cogging again , no solder bridges , changed the sensor wire again , still cogging ..... finally stopped running, removed it from the car, checked it on my motor checker .... NO sensor lights AT ALL ...... Sensor board is bad . Contacted R1 via their website, supplied them with my proof of purchase ..... was hoping they could send me a replacement sensor board (without me shipping them the motor) ..... I will send them back the bad sensor board if they wish. Thanks, Rich Boehmler
Also if you you have technical issues you can contact them via the phone number.
#686
#687
Only the first batch (yr old) are actually roar legal . only 1 r1 I'm aware of made it thru tech at a roar event . now I'm told the ir isnt below USVTA standards ...but based on the submitted motor all the newer motors are below those specs (which means they are not legal ) . so be warned if a race you attend goes by roar #s it probally will not pass
#688
with all these sensor boards going bad, i wonder if they're shimming the rotor too close to the sensor board. i had that happen to me with my monster max. sensor board went bad after like 3 race days. bought a new board and shimmed the rotor one shim further away and haven't had any issues.
#689
#690
