R1 Wurks brushless motors
#572
There are two 6000mah batteries on the R1 site. An LCG battery and a regular one... Does the regular one have much better IR? Or are they about the same?
#573
#577
idbdoug
#578
R1 wurks v16
Hello, if anyone is interested, I have a brand new r1 v16 motor I just bought from rotor Ron. Never run. Only soldered in my car, and then my club went to a spec motor. It’s a 17.5 and will come with all the rotor Ron paper work. Paid $119 but willing to discount it a bit as I have no use for it. Let me know, thanks guys
#579
I would personally stay from 12.5 high torque and stick with the stock 12.5 because the cars are so light. When we used to run 21.5 F1 and I had a problem with the inside tire getting loose with all the power. If u r using a fenix gear diff you might be able to get away with a 12.5HT but start with the stock rotor first . Car will be stupid fast with a 21.5
idbdoug
idbdoug
Our rules f1 is 21.5 just wanting to try and run it for fun hoping to find a ball park starting point for gearing
#581
R1 V16 17.5 with standard rotor. Also have ran 1700+ rotor lately, felt best with same gearing and timing below. Note: This is with the one motor i'm using. Others could be slightly different. But in general these settings should work for most.
I've tried 3.8 to 4.6 fdr's in .2 increments from 30 to 55 timing. Lot's of track time. These all seem to be good
3.8fdr - 45 tmng
4.0fdr - 47 tmng
4.2fdr - 50 tmng
4.3fdr - 52 tmng
Motor may run a little hot, but with all my testing when the motor ran about 165-170 is when I hit hot laps and best avgs. I measure temp from the top of the motor about 30 sec after being on the track for 320-340 sec. Track size is 96x42 feet CRC Black carpet. Using a R1 fan mount with WTF fan connected to receiver and ORCA VX3 ESC.
If you run on a smaller or larger track you can adjust FDR and timing. I also raced at a small track (60x40) in Fort Collins Wed night. My best laps times where with a 4.6 fdr and 47 timing. Longest straight section was about 45ft. I did this to get up to speed as fast as possible. Cut several tenths off my avg from running gearing for a larger track.
I've really tried to make the Dyno results posted by Jorge work but the car never felt fast on the track when in the 25 to 35 timing range regardless of gearing. The main reasons i think is because of the torque loss due to the large FDR.
3.8fdr - 45 tmng
4.0fdr - 47 tmng
4.2fdr - 50 tmng
4.3fdr - 52 tmng
I found that my timing and rollout best performance also coincides with about 160-170 degree temps and that was on a 1/12 Setup around 3.2 amp draw and 93 rollout on a 40x75 track. No fade either.
#582
xtrememadness's Avatarxtrememadness , Yesterday 09:27 AM
R1 wurks v16
R1 wurks v16
#583
