R1 Wurks brushless motors
#511
What were some people at IIC geared and timed at for a 21.5 V16 in 4wd TC? Looking for recommendations.
#512
You will hear this whine with many esc's and motors.
When you have an esc that allows you to adjust the PWM frequency past 12khz, the noise is lessened.
Its the motor making that noise based on the esc settings.
#513
I did more research. I now think the frequency was to low/Not good firmware. The only info I could find was mostly from rc airplane websites and guys building there own esc. Seems poor firmware from cheap esc s waste energy and make noise. Good quality esc s make the noise go away. I tried changing my timing and it sounded the same.good luck. Found this from ****its normal for an esc with a PWM frequency set from 8 to 12hkz to whine.
#514
#515
New rotor upgrade for stock motors. The 1650 rotor is the sweet spot for torque/RPM's for R1wurks motors
https://r1wurks.com/collections/moto...ue-tuned-rotor
idbdoug
idbdoug
#516
idbdoug
#517
No. None of my esc s have adjustable pwm. At 1 of the club races a team Orion driver commented on the noises my motor was making. I searched and found info from drone video guys and rc plane guys discussing motor noise.so I switched my firmware to a few different 1 s. Still noisy. So I installed mamba x. It now has no noise and runs cooler. MAMBA X, 25.2V WP ESC, 8A PEAK BEC, DATALOGGING. It's over kill and designed for powerful starts (rock crawling) but whatever.
#518
Hopefully R1 chimes in on the noise. I don't mind it if not negative performance issues. I know it's not the esc, Hobbywing makes some of the best in the business and makes them for other brands out there. Might be just a combination of the new rotors with the sensor board layout creating the extra noise. I've had motors with killer rotor numbers and used a few different frequencies in the esc and never noise like this. Just very odd.
#519
L lp
I just had to take the bait. Nice work.
Careful. If they were 1 of the best esc s you would not have strange noises. It's hobbywing not NASA. Lol. I am sure hw will modify there firmware and it will be good.
#521
I've built several R1 V16 17.5s and 21.5s, both with and without the 1750 rotor.
When I built the first motor with the 1750 rotor I noticed the squeak when the motor was about to start on the dyno.
The same motor with the original rotor did not squeak as loud and none with a 12.3 rotor.
The 1750 rotors read in the range 1680-1700gauss in my facts machine 2.
The regular rotors I've tested read 1490-1525 gauss. That is quite a big difference.
The rotor being so strong takes more throttle input to start the motor and in my opinion is what making the lound motor sound.
#522
The rotor being so strong takes more throttle input to start the motor and in my opinion is what making the squeak.
#524
#525
The Hobbywing ESC's apply power very smoothly, while other ESC's are like an on/off switch. With that smooth delivery of power, there is a range at the very start of throttle input where not enough power is being delivered to turn a motor with a ton of torque (maybe the first 1 - 3% of input). This usually only happens when you start from a dead stop. Once you increase the throttle input past that point, you shouldn't hear the noise. You can increase the Initial Throttle or Punch setting or Throttle Curve on the ESC to make it deliver more power at the start of input if it bothers you.
If it is making that noise constantly, take it apart and check & oil your bearings, check your sensor board and also make sure the motor didn't inhale a shim/screw.
I run a XR10 Pro and XR10 Pro 1S @ 4k Frequency in TC, F1 and 1/12th w/ V16 HT and Standard Rotors.
Hope that helps ..
Joey
