DC Motor Sports Discussion Thread:
#841
Originally Posted by Curtis Schlaht
12 Degrees of timing is always a good starting point.... Comm should be cut every 3-4 runs...
Curtis,
Curtis,
Hi curtis, would the motor be more efficient if i cut the comm every run on an 8x1 Ti3?
thanks - jason
#842
Thank you sir,
Not only is the order in...heck you already got the order out....LOL
That is what I call superior Customer Service...A+ Curtis.
-Shookie <><
I hope those VXR packs are the shizzle....They seem to be the next thang in the evolution in RC batteries anyhow..Gotta Love progress...
-Shookie <><
Mr.Shookie: YGPM
Curtis,
Curtis,
#843
Originally Posted by Mr. Shookie
Thank you sir,
-Shookie <><
-Shookie <><
I have 1 of those VXR packs in my 3PK and its AWSOME i can race with my nitro all weekend and it wont go down a volt!
#846
Originally Posted by rayhuang
Curtis,
GO ahead with my order. I tried e-mailing you but it bounced back to me-so just posting here to make sure.
Thanks,
Ray
Thanks,
Ray
highwayman: YUP .... Although it isn't mandatory, cutting the comm every run will help with runtime.....
Mr. Shookie: Thanks for da order ......... Did someone say Customer Service
Alex: Sweet... Thanks for the testimonial.
Ray: HURTING!!!!! Hope that wasn't from my side..... Thanks for letting me know, like a said I'll get that out Tuesday.
Curtis,
#847
Also another thing bout the VXR pack:
if it goes below 9.0volts then its toast, and if you charge it, then it will catch fire
with my 3PK before it was a bit heavy with the 8 cells and now with 3 cells its friggen light!!!!
#848
Hey chris i was wondering what style of brushes does the Ti3 use, on friday i think im goin to order 1 with a Kr 19 arm!
#850
Ti3 uses a stand-up brush. Its a good can with a brush dampening system and onboard caps.
With a Ti3 I still cut it every run (just a skim) but the new silver brushes are good for 30+ runs with the same power as my V2's!
This is all for Sedan Mod with 7-8 turns.
#853
Originally Posted by F. Alonso
So not as good as the XXX silver brush?
Curtis,
#855
All three brushes are good, XXX, CS, Reedy 777...... Some are more expensive than others but performance amongst the three are nearly identical. Comes down to preference, and what's available in your area....
So far I've been more then happy with the XXX brushes, but I may get a set of CSs and see how they go with the Ti3.
