Hyperform Racing
#511
Lino, you go PM!
Sean
Sean
#514
Carlos-You should have your kit on Wednesday or Thursday. Let us know how it goes together and runs for you. Good luck at your regional!
J-You and Tim should be happy with them, we've had some great feedback already. I also got a call from Rusty over the weekend so it looks like you may have a third Hyperform 12 gracing your track.
#515
Hey, Just wondering about shipping to the UK.. do you do it?
I was wanting to put a company forum up on my site for you but i just wanted to check you can easily ship to the UK?..
#516
Let me know the address for your site so I can help provide direct customer support. Thanks!
#517
The address is www.uk-rc.net/forum
If you register i can assign you to the forum with mod controls.
The forum isnt actually there yet so dont get confused. It will be inside the "Companys, Organisations and People Forums!"
Traffic is steady at the minute but i like the look of your products and hopefulyl so do other visitors.
I will get it on tonight.
Thanks,
Thanks,
#518
Ok great, I registered under username "Hyperform Racing”.
#519
Had a chance to run the Hyperform 12 production version for the first time tonight. Been a little a busy the last couple of weeks. Simply dialed, it just ate everyone alive in the corners with it's corner speed. Very very pleased...
#520
Hey everyone, I finally got a chance to finish the Hyperform 12 assembly instructions. I've also posted them on the website. If you purchased a kit and would like to check them out, here is the link...
http://www.hyperform-racing.com/Hype...structions.htm
#522
Hey Carlos! The associated plastic spacers are part number 4542. I believe that comes with the t-bar spacers, antenna mount and damper disks. I don't think you can get just the spacers from AE but I could be wrong. It's happened before... You will need to file down the spacers to the appropriate thickness in order to get the rear pod bottom plate level with the chassis.
You could also use any spacers/washers you have lying around as long as you can get the pod plate and chassis to sit on the same plane.
