Team ORCA USA Discussion Thread
#816
I am interested in when the new ESC will be released.
#818
Could anybody tell me in case of TC 17.5 blinky stock class, if RT or old TX motor is better?
Best regards
Best regards
#821
#822
At least could you tell me what size are the RT rotors, please?
Could you tell me too if your handout motors in last IIC was fixed or adjustable timing, please?
Best regards
#823
> RT 17.5 for carpet - start with an FDR of 3.7 to 3.8 with 52* of timing. Check your temps after 2 minutes of the initial run and adjust accordingly.
> The RT 17.5 uses the 12.5mm rotor (ORR425SO). You can find the other rotor options depending your application here: Accessories | Product Categories | ORCA Team Ltd.
> The 2016 IIC handout featured adjustable timing.
#824
Could you tell me which motor could take lower fdr in carpet blinky race, please?
#825
Orca R32
Hi
Do any have problems with the R32 not accelrate normally. From 5 to 60% gas it is not responding to the throttle , feels like a sensor problem but if i raise the car so its in the air there is no problem.
Have tried new sensor wire and motor.
Also tried different settings in speedo.
All with no response.
Have heard that maybe a firmware update but when connecting program box with sd card it says no file , and they are on the card.
Have also seen the update video on youtube , and that update file version I can not find.
Thnks in advance
Thnks in advance
