Like Tree1Likes
BMI Racing Discussions
Old 01-10-2006, 11:40 AM
  #8836
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Bob Barry
Because the BMI moves the electronics in and forward it has a more aggresive feel when driving. BMI is also 3.0 mm thick as compared to 2.5 for the FT. I think that the BMI will give you an extra few tenths per lap if you can wheel it.
Thanks again ..I'm will copy your set up......
OVA is offline
Old 01-10-2006, 01:25 PM
  #8837
I don't have the FT TC4 so I can't compare but the BMI TC4 is fantastic! I used the setup on Associated's site for outdoor asphalt, large flowing layout. The car is very stiff and stable, can handle a lot of power, has good low speed turning and is very adjustable. For me, someone who has been racing only a couple of years now, the BMI TC4 improved my driving immensely.
To be honest, it made TC racing fun.
Thanks,
Matt
mpetrich is offline
Old 01-11-2006, 09:45 AM
  #8838
Default BMI 1/12th scale
I just got my BMI conversion.
Wow!!!! The workmanship is spectacular!
Can someone please post a good carpet set-up, so I can get this thing on the track ASAP?
Any special tweaks for this chassis?
r1sportbike is offline
Old 01-11-2006, 10:07 AM
  #8839
Trader Rating: 22 (100%+)
here was my latest setup.
Front
70 wt losi oil
2 piston
purple springs
inside on arm
2nd hole out on tower (laid down)
camber - 2nd hole out silver ball stud no washers
4 deg castor
5mm ride height
droop - 2mm over ride height
steering rack - silver ball studs no washers
2 shims in front of arms
no shims under blocks
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
Losi XXXS Zero deg hubs inside on hub no washers
no washers under blocks
5 mm ride height
droop - 2 mm over ride height
double pink
no sway bar (this made a huge difference)
BMI Chassis/top deck/ motor mount
Team Express C2 (19T) geared 35-104
Team Express IB3800's
Parma Alfa
Bob Barry is offline
Old 01-11-2006, 01:25 PM
  #8840
Default 12th scale
Sorry, I wasn't clear.
I'm looking for a BMI 1/12 scale set-up.
Old 01-11-2006, 02:35 PM
  #8841
Front
70 wt losi oil
2 piston
purple springs
inside on arm
4 deg castor
5mm ride height
thickest sway bar
Double Pink/Orange
Rear
60 wt losi oil
2 piston
copper spring
outside on arm
5 mm ride height
double pink
Parma Alfa
I just got my BMITC4 going and have just a few questions about your setup. What front and rear arm spacing do you use? What ballstud(silv/black)/washer combo do you use on your steering knuckles and rear hubs? And what rear arm mount combo are you using?
Thanks LJae
LJae is offline
Old 01-11-2006, 02:45 PM
  #8842
protc3's Avatar
30 wt oil in center shock
olive green spring
.020 front springs
.075 t plate
i use all 3 screws where t plate attaches to the lower pod.
100 wt shock oil in damper washers
4mm ride hieght at rear of chassis(not pod)
3.5 mm ride height at front of chassis
1.800 diameter grey rear tires
1.700 diameter front purple tires
make sure rear pod is level
parma speed 8 body
this is for stock 1/12th.let me know if i missed anything.
protc3 is offline
Old 01-11-2006, 04:00 PM
  #8843
olive green spring
.020 front springs
.075 t plate
parma speed 8 body
what about caster blocks and front camber?
battery position?
spur gear size?
thanks
Old 01-11-2006, 05:22 PM
  #8844
theisgroup's Avatar
this is pretty much a stock l4 setup so I assume
1 degree neg camber
1 degree toe in to zero toe
10 degree blocks 1 shim either side
96 spur
batts about 1/8 back from full front
theisgroup is offline
Old 01-11-2006, 05:37 PM
  #8845
protc3's Avatar
sorry about that.10 degree castor 1 shim in front and rear of arm.i always start with the batts full back and creep them forward until the car smoothes out to my liking.
protc3 is offline
Old 01-11-2006, 05:39 PM
  #8846
protc3's Avatar
i start with 1 degree of camber.if the front bites too hard i go to 1/2 degree.i go with just a hair of bump toe out also.
protc3 is offline
Old 01-11-2006, 07:30 PM
  #8847
lmunno's Avatar
Just want to wish Tim Stamper a HAPPY BIRTHDAY!!
lmunno is offline
Old 01-11-2006, 09:10 PM
  #8848
Thanks LJae
I have the arms spaced in the stock setting. I use silver ball studs everywhere. The steering knuckles I think were 2 washers...basically you just want to make the link parallel with the arms. I was using the 2.0 degree mount but I would suggest the 3.0 with the circle block. rear hubs get no washers.
Old 01-12-2006, 01:56 AM
  #8849
Trader Rating: 14 (100%+)
Hi,
and ConGarts go out to Tim S. as he is a Uncle now!!!!!
Jesse:
Hi,
hope your having fun with your B.M.I.TC4. Bob will steer you in the right direction. I just gave up and switched cars.
Mini loves his XRays.
TimXLB is offline
Old 01-12-2006, 07:44 AM
  #8850
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
TimXLB how have you been? Have you been all tuned up now or you still working on that. Hope everything is back on track for you.
Brian
wyd is offline
