Diggity Designs Custom R/C Components
#661
Thanks for the quick returns of my e-mail. Just wonder if some could post a good rubber setup.
#662
I was also wondering if the kit came with sway bars or if they needed to be purchesed?
#665
ok thanks
who do most people run the battery wire on top or underneath the drive shaft?
#667
Got my car, can't wait to get it together. I started working on my car, and my steering keeps binding up, would a lube help in the movement?
#669
Damon
#671
I'll try those things.
#672
Car is all set to go, just wondering what is a good starting point for a setup. Would it work if I set it up like my tc3? I was also wondering what people were running for shock lenghth. My rear is at 6.5mm and I'm trying to get down to 5mm and the collars are all the way up.
#673
Go here for a good starting setup for rubber: http://www.diggitydesigns.com/downlo...et_Outdoor.pdf
I also got your messege and will ship your stuff to your new address!
thanks, Damon
#675
its the 2 piece, it is a lot smooth with lube, I looked at that setup and it seems a lot different then what I was running on carpet.
