DARKSIDE MOTORSPORTS - "We Are What's Next"
#586
So maybe the problem I'm having is the fronts are building too much grip over the day and as a result the car is loose at the end of the day. Initially I had the white springs on the outer holes with 1000 weight oil and it really did the same thing so yeah maybe the problem is at the front end of the car.
#587
#588
I've been racing stock indoor asphalt and haven't had any problems with purples. But, I tried 19T the other day and 3 minutes in the purple's where heating up fast and starting to over steer mid and exit. So what brand black's (crc or parma's)? I'm going to be racing 19T outdoors at the eXpress Paved Championships in June. I'm going up in May for some practice. I'm okay with setup. Was not sure on tires. I have Parma's, CRC's and Jaco 2 stage all flavors.
#591
#592
Originally Posted by THE DARKSIDE
I'm kind of partial to the Jaco's myself
#594
The offices of Darkside Motorsports will be closed from April 19th until April 25th. All orders placed during this time will be shipped after we return
Bad donkey--no cookie. Thought you were tied to the CAD until the MX12v2 was finished, so that could only mean...
#595
The last set of tires I used were Jacos...it was really strange...I had to CA the edges of the tire again and some dripped down into the screw holes. I looks like the CA actually melted/softened the plastic in the screw hole because right after that is when I had the screws pull right through the plastic when I tightened them.
#597
Sent a Mail to you DS MS, about the I-Force
/Thomas P
/Thomas P
#599
After it is made the best it could be
