Ask Team Tekin
#976
Hope this helps.
#977
I'd like to see Randy's answer too, but for me it is was the radio - a Spectrum in my case. When I calibrated the radio to the ESC using 100% on the radio end point I only got ~80 throttle on the ESC read out. I recalibrated using 120% on the radio then I got 100% throttle on the ESC readout and the car was faster. After calibrating the radio and ESC I also detune the motor to the track conditions (I race dirt oval now) by adjusting the radio end point so I don't over power the track.
Hope this helps.
Hope this helps.
#978
Hope this helps.
Hope this helps.
Another quick check is to power up your ESC and hit WOT and verify all LED's ramp up and then flash all at the WOT mark.
#979
That numeric figure is not a percentage of YOUR throttle input to the ESC. It's a figure that is based on the maximum allowable throttle singal we accept. As long as you are seeing "Flats" in the log you're getting wide open throttle to the ESC.
#980
Hi Randy, one of these days I'm going to learn to not disagree with the experts, but I'm going to here. Just because you see flats and all the LEDs light up at WOT is not the same thing as using all the available throttle voltage unless that flat also occurs at 100%. If the WOT Flats don't occur around 100%, you are only using a fraction of the full throttle potential that your ESC can provide - perhaps a better interpretation than % of throttle position. For illustration unrestricted my full throttle Flats occur at 100% on the ESC but if I give the same car to a novice and slow the car down by adjusting the throttle end point to say 60%, he/she will have full throttle flats (and all the LEDs will flash) but the Flats will be at a lower percentage and hopefully they will be slower than me. BTW when racing, my WOT flats occur between 75 and 80% and all LEDs flash at Full throttle (I just checked) and I know the SCT I use for dirt oval is a lot faster at 100% than at 80%, but the track conditions won't hold the faster speeds.
If your WOT is happening at 70% throttle input you did not calibrate your ESC properly, period.
If your'e one of those guys that calibrates at 100 on the EPA then pushes the EPA up to 140 or whatever this is why your WOT is at 70%.
#981
This statement is true and accurate to a point. If you used EPA's to slow the car down it would indeed show a "flat" since the high point would stop going up. However the LED's will not all light up and flash which is the 2nd of 2 parts required for my statement to be accurate.
#982
OK time to eat some crow! I calibrated one of my other ESCs to 100% end point on the radio, 100% brake and no throttle trim (Randy these are just too easy to do to not calibrate correctly). Ran the motor and got the following ESC read outs 80% throttle and motor rpm 28.4K Reset transmitter end point to 65% and ran the motor. Only some of the LED lights came on, just as Randy said. ESC readings were: 57% throttle and motor rpm was 26.7K.
I recalibrated the radio/ESC using 120% endpoint and ran the motor. ESC readings were: throttle 100% (the same finding I got from my 1/10th scale ESCs) motor RPM 28.6K (very minor gain in RPM). Next I changed the endpoint to 65%, ESC readings were: 57% throttle and 26.4K rpm. Only some on the LEDs came on. Next I put the end point at 90% (about where I run) and the ESC reading were 77% throttle and 27.1K RPM. All the LEDs came on but did not flash. Only time the LEDS flashed was when the end point used was the same end point the ESC was calibrated to.
What I missed in Randy's first email was the LEDs did not flash, they only ramped up, all were illuminated at the end point I was using, but they did not flash!
I'm also very surprised at the minimal gain in motor RPM between 80% throttle reading and 100%. That of course is static RPM and doesn't measure acceleration, but still surprising! PS that was also using a 4S battery.
#983
No worries.
If you calibrate at 100 and go up from there all you're doing is shifting your WOT set point lower in the trigger travel. You really shouldn't see any WOT rpm variance since "on" is "on" lol.
The data logger again isn't a percentage of your throttle, it's the precentage of the maximum allowable WOT signal we'll accept in the software.
#984
When is the G3 SpecR 17.5 motors due to hit the market?
#985
#987
That said the yellow high torque rotor is standard since we felt this is what our team is running 99% of the time. This coupled with our new stack design, low resistance stators, and good numbers on other measurements we're all familair with make a great motor.
Yes these are high revving motors, typicall 3-4 teeth in 48p lower than typical 17.5 gearing for example.
#988
i run a a 30/69 with a team type blueprint motor, can't go to 29 or lower for three teeth pinion drop, what should i look for to add in spur gear teeth for these new R specs?
#989
Spur/Pinion x Trans ratio = FDR
