Street jam OTA-R31 chassis
#31
Today test my OTA front oneway, at last the car is running. Feels way much much better. In fact , i can say it is a MUST to have front oneway for overdrive cars. If not , the front wheels will act as brake once throttle is release and the car will go straight even with the front steering turn.
Now the problem is the rear, swing way too much. Maybe i change to softer springs and test again.
#35
I went for driftevo comp yesterday,closed to DS F4 tires.
With tis tires n e setup im using suits my car very well,i can jus throw my rear n still be in control,with aggressive angle n speed.
Im able to paste 4x4 cars with tis tires.....great.
#37
Wow......nice job.
Fine tune ur car,sooner or later u'll get e same result....hope u can achive tat.
I never tot of tat in e first place,cause i break e original ball diff holder inner wall when i do e installing.....so fed up wit it n decided to use TA05 spool instead.
#39
Nop....so far so gd.i only wrap e cups wit glass tape only to pervent from e uj pin from popping out.
#40
I have tune down my CS ratio from 2.24 to 2.1, spool the rear , tamiya red soft springs at the rear, tamiya blue hard up front.
This weekend will test run at sk again.
Hope for more improvement .
Last sunday at woodland,at last i can CS at sweeper oridi, But verli stress, car not that stable, very loose.
#41
Try to go low on ride height it helps a bit,n try to lower ur rear camber.
Im now trying on alu rims only on e front.....each rims is 35grams heavier than normal plastis rims....hope tis mod helps.
I wont b able to go to skdm tis wkend,to many errands to run n i need to prepare for SGdrifters comp on sun....haiz.....
#43
You play crawler too? Coz crawler add weights to the rims. Low CG, more traction.
For CS, wat is ratio of weight distribution between the front and the rear?
As i c , our streetjam the front is heavier. However the yoko DRB the bat. is mount more to the rear.
#45
I more comfortable wit heavier front.....cause wit front 1-way,its makes my rear swing less sudden in doing dori.Even my cyclone is setup wit xtra 95grams to its front bumper.
Originally weight distribution for streetjam chassis is 60% front,40% rear.
Im trying to get 80% of its weight to e front.
For drb chassis is 50/50 weight distribution same as 1/1 AE86 chassis..
