Street jam OTA-R31 chassis
Make: Street jam
Model: Ota-r31 Track surface: SKDM blk 186 (tiles) Tire: T-Drift Motor & ESC: LRP,8.5T Front Camber: 13deg Toe: -1 Kick up: - Caster hubs: 7deg Ride height: 3mm Springs: tamiya (hard) Bumper weight: none Trailing Steering Block: stock Sway-Bar: none Shock Oil: Hpi 30W Other: none Rear Camber: 3deg Toe: none Kick up: none Ride height: 5.5mm Springs: Street jam (s/soft) Sway-Bar: none Shock Oil: Hpi 80W Other: Drive Train Gearing: TA05 Front 1-way/TA05 Rear Spool Pulleys from street jam cs kit Front pulley: 39/17 Center pulley: front 22T, rear 14T Rear pulley: 36T(TA05)/21T Spur: 90T/48 pitch Pinion:21T/48 pitch Ratio: 2.1% |
Hi bro, i also own OTA, playing at SKDM last sunday.
Would like to ask you about the pulley. Your rear pulley using 36T/21T, will the 21T small pulley hit the belt cover and chassis? Coz i try installing the 19T pulley oridi like hitting the belt cover and chassis. |
Originally Posted by RTECH
(Post 8591985)
Originally Posted by 7colours
(Post 8592723)
I did not encounter such problem on mine......its should fit just rite.n im not doing any modification on e belt cover. Maybe we can meet @ SKDM after CNY,i can a look @ urs.
(Post 8596424)
Oo.. ok. Thanks. How about the belts? Did you replace any belts, with short ones or you just adjust the diff. spacer?
(Post 8598402)
I didn't change any belts but only mod my cyclone tensioner to tension my front belt,cause im using 17T instead of 18T.
:confused: My setup is Front: 39T/16T Centre: 22T/14T Rear: 39T/18T Cs ratio: 1.77 |
(Post 8601976)
Ay? But my front i using 39T/16T , i only adjust the spacer, no need tension ley.
For the rear, if using the 39T diff.pulley with the stock belt , the small pulley cannot be more than 18T, otherwise even if you adjust the spacer , the belt will still be very tight.
(Post 8603539)
(Post 8603923)
I encountered e same problem wit my front belt when i use 39/18T,tat is y i decided to use 17T instead of 18T. N I need some belt slack for better transition btw on to off throttle
Does your inner wheel fully turn when your steering is turn fully?
My inner wheel not fully turn when my toe is neutral. Have to toe out then the inner wheel turn fully. Coz when the steering is turn fully, the outer wheel turn fully 1st and locked , this prevent the inner wheel from turning further. Do u encounter tis scenerio? |
(Post 8608023)
My inner wheel not fully turn when my toe is neutral. Have to toe out then the inner wheel turn fully. Coz when the steering is turn fully, the outer wheel turn fully 1st and locked , this prevent the inner wheel from turning further. Do u encounter tis scenerio? There a small stopper attach to e diff cover,cut it flat n cut its steering turn buckle a little bit short if u cant get ur steering to 0deg toe then u should have 0 hackerman in full lock. |
Regarding about those street jam wheels. My tires easily pop in and out of the rims when hit the tire markers.
Seems that sponge tape use to hold the tires is not working. Did you glue it ? Wat kind of glue u use? I try CA still pop out. I am using those old school rims. |
(Post 8612953)
Regarding about the Ta05 front oneway, Wat is the thickness of the spacer you put to make the diff. pulley centred?
Where can i get those spacers? |
