Speedpassion Brushless. >
Old 01-09-2008, 09:13 AM
  #826
lutach's Avatar
Originally Posted by makytc4
yeah hes right just did it on mine with throttle in normal and car goes backward
If you are using a sensorless motor, swap any 2 wires on the motor.
lutach is offline
Old 01-09-2008, 02:09 PM
  #827
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Victor Vector
Just checking, Orion 3200 LiPo cut off voltage should be set at.........?
Jacko
set it for 3.4 jacko.....
j/k i have mine set at 3.2
see you in tri-cities, i got that traction rolling thing figured out, its on now..
skypilot is offline
Old 01-09-2008, 03:13 PM
  #828
Jacko
any lipo should be 3 volts per cell. Assuming that the 3200 is a 2 cell pack, 6v is the way to go.
chris_dono is offline
Old 01-09-2008, 03:44 PM
  #829
Victor Vector's Avatar
Jacko
Adam E-mailed the answer to be #5 for racing. He says he never would run below #5.
So, be careful there Richie. (et al)
Jacko
Victor Vector is offline
Old 01-09-2008, 04:27 PM
  #830
abailey21's Avatar
Trader Rating: 37 (100%+)
Shawn and I agreed that 3.0 is the absolute lowest that you should have it set at.
(which neither of us recommend by the way)
I said #5 which i believe is 3.2?? only because its ALWAYS better safe than sorry.
My goal is not to extend per say, but make sure you can utilize the entire life-span of your battery, and that one of our products isn't the reason its been cut short.
If your solely using this battery/speed control combo for racing, it won't really be an issue because even in practice you normally will only run 8 min max at a time, and the cutoff voltage wont even come into play...normally
abailey21 is offline
Old 01-09-2008, 11:06 PM
  #831
JayBee's Avatar
Trader Rating: 31 (100%+)
Adam, check your email
JayBee is offline
Old 01-10-2008, 10:33 AM
  #832
Man Alive, this is a blistering set up. Night and day to the Novak. The programability is astounding. Ran 5 lipo packs last night (1 pack 5 times that is). Set # 3 at 5 as per Adam's message-fine. Just to see what happens, I set #3 at 6, highest cut off voltage, thinking there might be a voltage drop glitch; no a one in a five min heat plus 1 minute warm up !! Played on the punch setting, starting at 8=great, one heat at 6 got me quicker, one heat at 9, got me faster !! Know what's coming from this ?? But who can resist that punch......
Didn't have time to play with the reverse brake (?) function, in fact, it's a bit of a contradiction in my febble mind sitting here at a terminal. Better read the book when I get home.
Jacko
Old 01-10-2008, 11:54 AM
  #833
Dan the Man's Avatar
Trader Rating: 41 (100%+)
How much space does the GT take up? Is it equivalent to a GTX, or bigger? Also, I noticed no fan, just a heatsink. Do you need to add a fan to run it, or passive cooling is ok?
*wants to buy one*
Dan the Man is offline
Old 01-10-2008, 11:59 AM
  #834
Trader Rating: 42 (100%+)
*wants to buy one*
The GT comes w/ the optional fan. Size wise it's about the same as other BL speedos from LRP and Novak.
Nexus is offline
Old 01-10-2008, 12:13 PM
  #835
RC MARKET's Avatar
Trader Rating: 12 (100%+)
but in HK many race not have Win !!
RC MARKET is offline
  #836
abailey21's Avatar
Using a 17.5, 13.5 and 10.5 the speed control doesnt really get hot enough to require a fan. But you could use it if you wanted.
Size wise its comparible with most other BL Speedo's on the market
*wants to buy one*
Old 01-10-2008, 12:25 PM
  #837
theisgroup's Avatar
*wants to buy one*
same width as the lrp tc but i a little longer
theisgroup is offline
Old 01-10-2008, 12:50 PM
  #838
razzor's Avatar
Yet !!
razzor is offline
Old 01-10-2008, 12:59 PM
  #839
Well one guy was in the A Main at the Novak TC Champs 13.5 class...could he have one..maybe. But it shows the GT ESC works as good as others.
Nexus is offline
Old 01-10-2008, 02:18 PM
  #840
Skiddins's Avatar
Is the GT waterproof/splashproof?
Skiddins
Skiddins is offline
