T.O.P. PHOTON EX >
T.O.P. PHOTON EX
Like Tree1Likes
T.O.P. PHOTON EX
Old 05-06-2012, 04:45 PM
  #421
haywood's Avatar
Trader Rating: 49 (100%+)
Originally Posted by hanulec
Yesterday we nearly had a rain out but thankfully got a lot of running in under the lights at Jackson RC. My car is coming around in 13.5 blinky. Next week I'll race 17.5 blinky with both my Photon and EX back to back in hopes of proving how good my current setup is.
How much faster are the laps with the 13.5 over the 17.5 car? Thanks
haywood is offline
Old 05-06-2012, 05:13 PM
  #422
hanulec's Avatar
Trader Rating: 28 (100%+)
it depends upon tires...
i think at last year's nats the difference was nearly 1s at our track.
hanulec is offline
Old 05-06-2012, 06:14 PM
  #423
hanulec's Avatar
Posted my fastest setup from yesterday.
http://racerlog.com/wiki/T.O.P._Photon_EX#Setups
Yesterday I think I really learned the impact that rear width makes, above and beyond rear toe. When I went from RF 1.0/RR 3.0 to RF 0.5/RR 2.0 the car really woke up, more than any wheelbase change. Additionally when I went to RF 0.0/RR 2.0 the car was as loose, or even looser although I had more rear toe. I think I'm going to run RF 0.5/RR 2.5 to start next week along w/ a longer rear wheelbase.
hanulec is offline
Old 05-06-2012, 06:47 PM
  #424
Chris08527's Avatar
Trader Rating: 16 (100%+)
haywood here are the top three zults from last years roar nats @ jackson on the same tire laps-time-hot lap . . .like mike said about 1 sec faster and 1 lap faster over the 6 min run . . .
17.5 Blinky A1
Scooby 23 6:11.67 15.75
Cuffs 23 6:11.95 15.78
DJ 23 6:12.74 15.80
13.5 Blinky
Hohwart 24 6:06 14.9
Tessman 24 6:08 15.1
Herbert 24 6:08 15.0
Mod
Lemiuex 25 6:06.3 14.6
Hohwart 25 6:06.7 14.59
Tessman 25 6:09.7 14.65
Chris08527 is offline
Old 05-07-2012, 05:41 AM
  #425
Shop Owner
nnick's Avatar
A friend of mine has issues with the shock's spring adgusting nut. It has big play and after a run it changes position!! He tried to force it with hand with same effect. That is the case with 2 of his shocks!
Any ideas what might be the problem?
nnick is offline
Old 05-07-2012, 06:10 AM
  #426
MikeXray's Avatar
Trader Rating: 73 (100%+)
Have to ask, does he have the oring installed correctly into the collar? (I assume this is what you mean by the shock spring adjusting nut).
MikeXray is offline
Old 05-07-2012, 06:21 AM
  #427
Shop Owner
nnick's Avatar
Yes, this is what I'm talking about. Are many ways to install them?!
nnick is offline
Old 05-07-2012, 07:18 AM
  #428
hanulec's Avatar
Nick - did he install the oring in the collar?
hanulec is offline
Old 05-07-2012, 07:52 AM
  #429
Jerry P's Avatar
Trader Rating: 44 (100%+)
some people i know didnt put them inside the collar the first time.
Jerry P is offline
Old 05-07-2012, 08:34 AM
  #430
MikeXray's Avatar
On the scale of wrenching fails, I've seen a lot worse from you! I do show up to races with a setup board and tools
MikeXray is offline
Old 05-07-2012, 08:35 AM
  #431
hanulec's Avatar
+1 I did that the first time I built xray shocks when I was a noob.
hanulec is offline
Old 05-07-2012, 09:58 AM
  #432
Luppi Stefano's Avatar
me too, I change spring adgusting...
the problem, for mè, is bad anodizing...
you can try with thread lock...small amount...
Saturday First Run with EX, isn't good day...the car is faster, but very difficult to drive, rear slips in medium corner...totally wrong ackerman, std setup isn't usable, next time new setup completely revised!
I have good feeling with Gear Diff no problem, only small leak from lateral o-ring
Luppi Stefano is offline
Old 05-07-2012, 11:04 AM
  #433
hanulec's Avatar
Luppi - what setup did you apply? Kit instructions? The EJ setup within the instructions?
can u elaborate on what you are planning to try next? Are you running the aluminum v2 steering blocks?
hanulec is offline
Old 05-07-2012, 11:55 AM
  #434
similar kit setup, only difference is 400 cps oil with 306 spring front and rear, gear diff 1000 cps
unfortunately I haven't V2 steering blocks, in italy we haven't yet!
planning to try a setup more similar to "old" Photon: 3mm ackerman, long links front and rear, front arms with 1FF 0FR, 1mm rollcentre RF RR, gear diff 2000 cps
Old 05-07-2012, 12:28 PM
  #435
Shop Owner
nnick's Avatar
yes told me he did
nnick is offline
