Tamiya TA05 Touring Sedan
#3857
Originally Posted by Slotmachine
Now last night I did have all 3 screws come out of my front one way....... Now they are locktighted in!!!!!!!!
#3859
this has happened to me this time when i was racing the belt slippped of the pulley and got stuck down the side of centre shaft next the bearing completely destroyed the stock belt bent twisted and shreaded, so i have bought some blue belts off stella models
#3860
cheers about the lube info as well
tamiyamanuk
tamiyamanuk
#3863
Thanks, I had to post that briefly as my boss was walking by.
Just to make sure before I go and get them. Are the aramid belts stronger? or are they just the same as the low friction belts which I'm told are actually weaker but have less friction.
Oh, and because I damaged the spur gear cover, is it worth just getting the carbon fibre brace that goes between the front and rear diffs instead? I figure that as I break things along the way, I might aswell upgrade them when they break.
also, can you get a metal centre gear? same idea as above.
thanks
thanks
#3865
Anyone here tried the Orion lipo packs yets? How much butchering is required in the stock chassis?
#3869
