TRF101
#616
I ran into a similar problem with the studs so I drilled out the hole a little bigger. I also used a very large drill bit to put a little chamfer on the hole, this helped with starting to thread the stud.
#617
Many Thanks - I dont have a proper drill, But I think I might have a pin vice drill somewhere. Cheers! Will give it a go.
#620
If not, I will have to try and find higher quality grub screws.
Cheers for the advice!
#623
I managed to get one of them sorted, but the one on the opposite side is rounded off - So, I cant get it in any further - Or get it out.
With Drilling it, How on earth do I get it out??!
#624
try using the closest none metric hex, there might be some edges to hold on to, or use a dremel and cut a slot and use a flat nose, sometimes a combination of heat and a slightly larger hex works charms
#625
To get the old grubs out take the body mount plate off the cars and remove everything from it so you don't damage anything else. Take the spring mount off the grub screw and use the side of pliers or mole grips to unscrew them, then throw them away.
If you need more grub screws, get them from Modelfixings
#626
Whatever you do, don't drill the holes larger or use a tap to cut threads, the plate gripping the grub screw is what keeps its setting. Run a normal screw through there first to form the screw threads, and use a decent allen driver instead of the kit allen keys, you will find it so much easier.
#627
hmmm, So It didnt go according to plan! I cannot get the damn thing out!
Anybody know where I can get a new Body Mount Plate for the TRF101?
#628
You could try this. If you have or can get access to a pair of vise grips you can clamp those down on the top of the grub screw and ease it out. Use just enough force to grab the screw but not crush it. Have used this method to remove all kinds of broken or stripped things.
#629
#630
Completely messed this up! And of course dont have access to a drill!
Just for comparison - The opposite side threaded fine:
Someone help! I feel like a right twat!
Without a drill or vice grips or a dremel, Is there any way to remove this?
If not, Is there a 3rd party part to replace the body mount plate, or does anyone know when spares will become available for the TRF101?
Cheers guys!
