Like Tree3Likes
TRF101
Old 08-20-2013, 03:32 PM
  #646
Originally Posted by aloksatoor
Thanks Dan for the tips. Yeah for norcal looking forward to it! Whats the hot motor at norcal team powers short can or I was thinking D3.5 maxzilla seems to have the most rpm 2900kv I believe! Also shorty I assume would still make weight at our track?
PS these ones ?
http://www.tqrcracing.com/shop/produ....asp?p_id=2908
They are in stock now
The TP short can will put too much weight on the right side of the rear pod. Get a regular sized 21.5T.
There are a lot of different motor brands being run at Norcal. Novak, Trinity, etc. I'm using an old skool Fantom D3 motor. Just need to gear it correctly. If you need help just ask.
A shorty pack should make min. weight of 1050g.
I would get the carbon version of the side links and center football piece you posted from TQRC's site. TQRC is outta stock right now.
Sydewynder is offline
Old 08-20-2013, 03:45 PM
  #647
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
I don't think the short can is ROAR legal either. The full sized Plutonium motor is. Its a popular motor at the track and supported at Norcal. I still think my D3.5 is a little faster and I'm able to do a 15 minute main without overheating. I'm running the eXpress D3.5 with 12.3 standard rotor. The Maxzilla has a 12.5 torque rotor I believe and should have a ton more torque while running even more cooler. But with F1, you want something smoother.
The fastest 21.5 I've tried is the Tekin 21.5 RPM motor. It is very fast but I ran into heat issues and had to turn down timing quite a bit. Still fast but the D3.5 is more linear throttle. If you'll be at the next onroad race, you can check it out.
Dan is offline
Old 08-20-2013, 04:02 PM
  #648
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Thanks guys I might not be done building mine by that race so will make it the next time. Are they running on road this weekend? Saw the calendar its only off road. Will probably order the D3.5 then.
I saw the carbon links on rcmart so might order them but build with the stockers for now tq is sold out and so is everyone else.
aloksatoor is offline
Old 08-20-2013, 04:14 PM
  #649
The next onroad race is scheduled for Sept. 1st. See you then!
Old 08-20-2013, 04:24 PM
  #650
aloksatoor's Avatar
Looking fwd to it!
Old 08-21-2013, 03:10 PM
  #651
simmo0916's Avatar
Hi Guys!
Many thanks for all the tips over the last month or so. It has been a great help. My 101 is now built, and I'm very happy with it. Made a few mistakes along the way, But with the help of this forum and a little bit of reasoning on my own part, It turned into a really fun build!
It wont be road worthy for another couple of months, as I still need a motor, Radio and battery.
On that note, Could you guys take a look at my Electronics plan and tell me If I'm going to run into any problems please?
ESC is a Reventon S. I plan to change the motor wiring for larger gauge wire, and change the Deans connector it came with to the 4mm bullet connectors.
Motor will be a Reedy Sonic Mach 2 21.5T.
Radio will be a Spektrum DX4s with a SR410 reciever.
Battery will be a shortly Lipo from Reedy.
Tyres will be Pits 571 and 572.
I plan to add a blinking red light to the rear of the car - Does this just plug into my receiver for power?
Anyways, Thats the next couple of months, Really cant wait to get this thing moving now!
Cheers for any input.
simmo0916 is offline
Old 08-21-2013, 05:38 PM
  #652
Electrics look fine to me
Here is a tutorial for a red flashing light
http://www.thercracer.com/2010/01/f1...-tutorial.html
Qatmix is offline
Old 08-21-2013, 05:54 PM
  #653
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by simmo0916
Hi Guys!
Don't want big wire for F1
16-18g is enough, and better for free pod movement
RedBullFiXX is offline
Old 08-21-2013, 06:48 PM
  #654
Personally I would go for the Hobbywing Xtreme Stock. The early Reventons weren't that reliable so got a bad reputation, but they are sorted now. The Hobbywings are quite popular, and are cheaper than the Reventon.
For wiring you want to go thinner, not thicker. Too thick a wire will act as a spring and tweak the rear pod. Thinner wire will allow the pod to move freely. The 21.5T motors mean you can get away with 18g wire.
This depends on whether you plan to race at BRCA events or not. If not you can use Turnigy nanotech lipos from Hobbyking for 1/4 the price of the Reedy pack. If you are planning on doing big events you will want a motor and battery from the BRCA homologation lists. Brushless motors are all very similar, it's more down to personal choice rather than motor of the month in F1s. My personal choice of motor would be Thunder Power or Speed Passion.
terry.sc is offline
Old 08-22-2013, 12:25 AM
  #655
-jacob-'s Avatar
my first Tamiya build... Now i understand why Tamiyas are soooo expensive.
Here is my finished product:
-jacob- is offline
Old 08-22-2013, 09:12 AM
  #656
Trader Rating: 39 (100%+)
That is a good looking car. Where did you find those wire separators? That is pretty trick.
Jamie Hanson is offline
Old 08-22-2013, 12:30 PM
  #657
simmo0916's Avatar
+1 on that - I need those in my Car!
Old 08-22-2013, 12:34 PM
  #658
simmo0916's Avatar
Hi there,
Im still working on my electrics for this car! But im struggling to see how you got all that in! Are you using a low profile servo? I am too, But I have nowhere near that amount of room left over! Whats the battery and servo If you dont mind?
Looks really good!
Old 08-22-2013, 01:35 PM
  #659
Rick Vessell's Avatar
Those look like spark plug wire separators. You can pick them up at your local auto parts store. Just extra weight IMO. And like the others have posted, you want small wire for the motor.
Rick Vessell is offline
Old 08-22-2013, 03:09 PM
  #660
simmo0916's Avatar
Is there some sort of rule of thumb for what size wiring can be used with certain motors?
You say 21.5T motors are fine with 16G wire - If I intend to run my TRF with a 13.5T for example, would I need bigger wire?
Apologies, I dont know a great deal about this sort of thing
