Like Tree248Likes
Xray XB4 thread
Old 01-14-2015, 06:50 PM
  #6436
rcgod's Avatar
Trader Rating: 33 (100%+)
I've never driven a wheeler with a center diff, but some of this talk makes me wonder if it would be better to go back to the slipper if you need to run 500k or higher diff fluid. Isn't that basically almost locking the center diff?
rcgod is offline
Old 01-14-2015, 07:03 PM
  #6437
Got the steel bevel diff gears in my '14! Loving it ... driving the car HARD without worrying about stripping gears. I did strip a couple before but I think that's because of the diffs getting a bit loose in the bulkheads ... should buy new bulkheads really.
I'm running with the 2mm plate under the rear gearbox. What's the benefit of having this/removing it? Not really sure ...
Thanks!
WagwanBumba is offline
Old 01-14-2015, 11:15 PM
  #6438
Thanks!
Running in the UK, I found that removing the 2mm plate made the car better over bumpy blown out grass tracks, much like it did on the old Yokomo BX when we used a one piece chassis.
You also have the option of replacing the plate with lead/brass to get a bit more forward drive in low grip conditions.
John Myall is offline
Old 01-15-2015, 01:09 AM
  #6439
vadersing's Avatar
New to Xray XB4, which after market wheels are suitable?
vadersing is offline
Old 01-15-2015, 02:02 AM
  #6440
Peakki's Avatar
Originally Posted by yunowill
Hey guys not sure how many people have had problems or wear on the car yet . But I am running my Xb4 15 at my local carpet track that has medium traction . Basically I am having a real issue with my outdrives and my outdrives on the slipper shaft both front and rear of the car . Not sure if any of you have had excessive wear on these parts but mine is getting pretty bad to the point that I'm almost second guessing this beautiful car because my wallet can not afford outdrives every couple weeks . This being said I have been staying on top and replacing my driveshaft pins .
if anyone can chime in on this that would be great
Thanks in advance
Some tips: Use durango drive boots on center universal joints, and slipper outdrives, and graphite grease to there. Use also same grease in diff outdrives (drive boots don't stay so well on there). Not so good looking but saves your wallet! Apply to diff outdrives with syringe&needle between runs, don't use excessive mount of grease.
Peakki is offline
Old 01-15-2015, 05:34 AM
  #6441
EricW's Avatar
Originally Posted by jmcelroy42
https://www.youtube.com/watch?v=SmfInldgGsc#t=248
This guy has a syringe with the tip cut off that he uses to push the fluid into the diff.
That's Paul Lemieux and that's his own brand of diff fluid. I was going to post this video but you beat me to it.
EricW is offline
Old 01-15-2015, 06:18 AM
  #6442
Trader Rating: 15 (100%+)
Raising the rear diff/tower etc. 2mm with the plate is lowering the roll center, I believe. This is beneficial on high traction tracks like carpet/astro, and high bite clay (slicks, maybe bar codes).
HeavyD99 is offline
Old 01-15-2015, 07:52 AM
  #6443
Trader Rating: 22 (100%+)
The fluid comes with the syringe which makes it very easy to fill a diff. Just give it some time, 8hrs or so, to settle before fitting it all back together to be sure the air is out of the diff.
Troy Carter is offline
Old 01-15-2015, 08:29 AM
  #6444
Trader Rating: 11 (100%+)
So I drove my xb4 15spec lastnight at Rc Clubhouse here in Michigan and it was a blast. I ran it with 8k/100k/5k and the car was soooo easy to drive. I was much faster going in and coming out of the corners. The only issue I had is that I was unable to clear the quad with a Orion r10.1 pro and 6.5t when others were able to make it, even in 2wd mod buggy. I am going to try 300k next and see how that helps. Overall I've got to say that the center diff is a Must Have item. So easy and such a blast to drive.
randy0025 is offline
Old 01-15-2015, 08:33 AM
  #6445
Trader Rating: 34 (100%+)
vppro 14mm
DustinEich is offline
Old 01-15-2015, 08:36 AM
  #6446
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
the center diff does take away that power snap that a slipper has. keep in mind a slipper is normally was "stiffer" than 100k. Doing up in center diff oil will give you more forward snap. But it will effect steering and other things as well. Just put a 5.5 in it, lol
Wildcat1971 is offline
Old 01-15-2015, 08:42 AM
  #6447
jmcelroy42's Avatar
I use DE Speedline for DEX410/XB4 because I like the colors better than the plain white/yellow.
jmcelroy42 is offline
Old 01-15-2015, 11:17 AM
  #6448
EricW's Avatar
Or you can use this
EricW is offline
Old 01-15-2015, 12:10 PM
  #6449
It raises the roll center, but the rest is correct ;-)
GregerL is offline
Old 01-15-2015, 01:54 PM
  #6450
You would be surprised how much diff action you get even with a 1000K....
Very different from running a slipper.
GregerL is offline
